Home » Modeling » GMF (Graphical Modeling Framework) » ContributionItemService problem
ContributionItemService problem [message #146551] Tue, 14 August 2007 11:43 Go to next message
Originally posted by: zzhangh.cn.ibm.com
I want to add an editor action to my gmf editor and I found
contributionItemProviders extension point can be used for this purpose.
However I tried to mimic logic example without success, the
"CustomContributionItemProvider" class's createTool() method was never get
called and of course no editor action showed up.
I listed the plugin.xml fragment below, anyone can give some suggestion?
<extension
id="contribution1"
name="contribution1"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
class="com.my.CustomContributionItemProvider">
<Priority
name="Low">
</Priority>
<partContribution
class="com.ibm.crl.bo.rule.diagram.part.RuleDiagramEditor">
<partAction
id="exampleAction"
menubarPath="/file/print"
toolbarPath="/">
</partAction>
</partContribution>
</contributionItemProvider>
</extension>
Hao
Re: ContributionItemService problem [message #149079 is a reply to message #146551] Wed, 05 September 2007 10:23 Go to previous messageGo to next message
Hao,
Did you get this working yet?
Cherie
Hao Zhang wrote:
> get called and of course no editor action showed up.
> <extension
> id="contribution1"
> <Priority
> name="Low">
> </Priority>
> <partContribution
> <partAction
> id="exampleAction"
> toolbarPath="/">
> </partAction>
> </partContribution>
> </extension>
> Hao
Re: ContributionItemService problem [message #149440 is a reply to message #146551] Thu, 06 September 2007 11:15 Go to previous messageGo to next message
Hao,
You can use either the id or the class of the editor. However, the id
and class of your editor for this purpose will be the values returned in
your DiagramActionBarContributor class's getEditorClass() and
getEditorID() methods. Your DiagramActionBarContributor class is
specified in your editor extension. Take a look a the
LogicDiagramActionBarContributor.
<extension point="org.eclipse.ui.editors">
<editor class="MyEditor"
contributorClass="MyDiagramActionBarContributor"
</editor>
</extension>
I hope this helps.
Cherie
Hao Zhang wrote:
> <extension
> id="contribution1"
> <Priority
> name="Low">
> </Priority>
> <partContribution
> <partAction
> id="exampleAction"
> toolbarPath="/">
> </partAction>
> </partContribution>
> </extension>
> Hao
Re: ContributionItemService problem [message #150288 is a reply to message #149079] Wed, 12 September 2007 03:19 Go to previous messageGo to next message
Hi Cherie,
My current situation is, I can contribute items from generated xxx.diagram
plugin, as logic and taipan examples did, but I can't contribute any item
in an outer plugin project, say xxx.diagram.custom which I created by
myself and depends xxx.diagram project. And I found no example for this
situation, yet I do need this because my actions has been defined in the
xxx.diagram.custom project and I don't want to modify much codes in
The other fact is if I implement IContributionItemProvider directly rather
than inherit AbstractContributionItemProvider, the
contributeToActionBars() method can get called when editor opens, so I
guess likely there is some logic in AbstractContributionItemProvider not
suitable for contributionItemProvider defined in outer plugin.. I'm trying
to locate..
Cherie Revells wrote:
> Hao,
> Cherie
> Hao Zhang wrote:
>> <extension
>> id="contribution1"
>> <Priority
>> name="Low">
>> </Priority>
>> <partContribution
>> <partAction
>> id="exampleAction"
>> toolbarPath="/">
>> </partAction>
>> </partContribution>
>> </extension>
>> Regards,
>> Hao
Re: ContributionItemService problem [message #150315 is a reply to message #150288] Wed, 12 September 2007 04:10 Go to previous messageGo to next message
Hi Hao,
I am facing exactly the same situation: I want to add a new action to
menubar and toolbar, but defined within an external plugin.
I also wonder at which point the visual aspects are defined (i.e. the
toolbar icon).
Please let us know if you cope with this problem.
Hao Zhang schrieb:
> Hi Cherie,
> xxx.diagram plugin, as logic and taipan examples did, but I can't
> contribute any item in an outer plugin project, say xxx.diagram.custom
> which I created by myself and depends xxx.diagram project. And I found
> no example for this situation, yet I do need this because my actions has
> been defined in the xxx.diagram.custom project and I don't want to
> modify much codes in xxx.diagram project.
> rather than inherit AbstractContributionItemProvider, the
> trying to locate..
>> Hao,
>> Regards,
>> Cherie
>> Hao Zhang wrote:
>>> Hi,
>>> purpose. However I tried to mimic logic example without success, the
>>> never get called and of course no editor action showed up.
>>> <extension
>>> id="contribution1"
>>> <Priority
>>> name="Low">
>>> </Priority>
>>> <partContribution
>>> <partAction
>>> id="exampleAction"
>>> toolbarPath="/">
>>> </partAction>
>>> </partContribution>
>>> </extension>
>>> Regards,
>>> Hao
Re: ContributionItemService problem [message #150887 is a reply to message #150315] Sun, 16 September 2007 02:26 Go to previous messageGo to next message
Axel,
Cherie helped me out, the key is to add
checkPluginLoaded="false"
in my contribution item provider extension, hope this also helps for you.
Hao
"Axel Guckelsberger" <info@guite.de>
??????:fc86tl$auq$1@build.eclipse.org...
> Hi Hao,
> toolbar icon).
> Hao Zhang schrieb:
>> Hi Cherie,
>> trying to locate..
>>> Hao,
>>> Regards,
>>> Cherie
>>> Hao Zhang wrote:
>>>> Hi,
>>>> suggestion?
>>>> <extension
>>>> id="contribution1"
>>>> <Priority
>>>> name="Low">
>>>> </Priority>
>>>> <partContribution
>>>> <partAction
>>>> id="exampleAction"
>>>> toolbarPath="/">
>>>> </partAction>
>>>> </partContribution>
>>>> </extension>
>>>> Regards,
>>>> Hao
Re: ContributionItemService problem [message #150898 is a reply to message #150887] Sun, 16 September 2007 05:42 Go to previous message
Hao,
I solved it by overriding the ActionBarAdvisor XPand template.
Hao Zhang schrieb:
> Axel,
> Hao
>> Hi Hao,
>> toolbar icon).
>> Hao Zhang schrieb:
>>> Hi Cherie,
>>> trying to locate..
>>>> Hao,
>>>> Regards,
>>>> Cherie
>>>> Hao Zhang wrote:
>>>>> Hi,
>>>>> suggestion?
>>>>> <extension
>>>>> id="contribution1"
>>>>> <Priority
>>>>> name="Low">
>>>>> </Priority>
>>>>> <partContribution
>>>>> <partAction
>>>>> id="exampleAction"
>>>>> toolbarPath="/">
>>>>> </partAction>
>>>>> </partContribution>
>>>>> </extension>
>>>>> Regards,
>>>>> Hao
Previous Topic:Again, how to change diagram layout?
Next Topic:Element creation
Current Time: Thu Jul 17 23:24:40 EDT 2025
Powered by FUDForum. Page generated in 0.25490 seconds
