Home » Language IDEs » Java Development Tools (JDT) » strange effect in eclipse help
strange effect in eclipse help [message #146538] Mon, 01 March 2004 11:09 Go to next message
Originally posted by: nospam.please.com
Hi all,
im using Eclipse and i think it's very very good, but im having
problems with the online help.
When i press F1 the help correctly loads, showing all the stuff
i wanna see BUT if i switch window (i.e. to Eclipse itself or
to another program ) and then come back to the help window, i can
notice a strange graphic corruption.
You can see a sample here
http://utenti.lycos.it/ecio78/messedup.jpg
Im using Eclipse 2.1.2 on Windows 2000 so, does Eclipse
use IE to show up these help pages ? Is the problem related
to MS browser or is there something wrong in my Eclipse ?
Thanks in advance,
Norberto Carnelil
Re: strange effect in eclipse help [message #146545 is a reply to message #146538] Mon, 01 March 2004 11:15 Go to previous messageGo to next message
You are using a version of IE that is not supported.
IE 5.5 is the minimum required.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=34920
HTH
Darins
"Norberto Carnelli" <nospam@please.com> wrote in message
news:c1vms0$c4l$1@eclipse.org...
> Hi all,
> Thanks in advance,
> Norberto Carnelil
Re: strange effect in eclipse help [message #146552 is a reply to message #146545] Mon, 01 March 2004 11:24 Go to previous messageGo to next message
Additionnaly, you can look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35009
The last comment includes a workaround
Hope this helps,
Jean
> HTH
> Darins
>>Hi all,
>>Thanks in advance,
>>Norberto Carnelil
"No brain, no headache"
Re: strange effect in eclipse help [message #146593 is a reply to message #146552] Mon, 01 March 2004 13:06 Go to previous messageGo to next message
Thank you both for the precious help,
i have IE 5.0 (never updated it because i
use Mozilla browsers)
i'll update it :)
> Hope this helps,
> Jean
>> HTH
>> Darins
Re: strange effect in eclipse help [message #146642 is a reply to message #146593] Mon, 01 March 2004 15:37 Go to previous messageGo to next message
Originally posted by: robwms63.yahoo.com
Why not just use Mozilla? It should work fine.
> i'll update it :)
>> Hope this helps,
>> Jean
>>> HTH
>>> Darins
Re: strange effect in eclipse help [message #146707 is a reply to message #146642] Tue, 02 March 2004 04:18 Go to previous messageGo to next message
you're right, but i dont think you can setup
Eclipse to point to Mozilla instead of IE when it
loads his help system (of course you can prolly do
it modifying eclipse sources, but i think it's not the
easiest solution :D)
Re: strange effect in eclipse help [message #146749 is a reply to message #146707] Tue, 02 March 2004 08:29 Go to previous messageGo to next message
Of course you can use Mozilla :
-> Windows / Preferences / Help :
- check "Custom Browser"
- and fill in the "custom browser command"
With Eclipse 3.0M6, at least.
Emmanuel.
Re: strange effect in eclipse help [message #146923 is a reply to message #146749] Tue, 02 March 2004 10:20 Go to previous messageGo to next message
You're right, same option present in Eclipse 2.1.2
Thank you very much ;)
Re: strange effect in eclipse help [message #146972 is a reply to message #146923] Tue, 02 March 2004 10:58 Go to previous messageGo to next message
now the problem is finding the right commandline
option to tell firefox "open the site in a new
tab" and *not* on a new windows (i dont want 500
firefox window in my taskbar :D)
Re: strange effect in eclipse help [message #146989 is a reply to message #146972] Tue, 02 March 2004 11:24 Go to previous messageGo to next message
According [1] and [2], I would try the following with Mozilla :
mozilla -remote openURL(%1l, new-tab)
Don't know if it works with Firefox (it should, IMHO)
Don't know either which window will open the new tab in case you have
multiple windows...
[1] http://www.mozilla.org/docs/command-line-args.html
[2] http://www.mozilla.org/unix/remote.html
Re: strange effect in eclipse help [message #147013 is a reply to message #146972] Tue, 02 March 2004 12:27 Go to previous messageGo to next message
Get the Tabbrowser Extensions for Firefox - it makes that behavior (and
much more) configurable.
<http://texturizer.net/firefox/extensions/#tbe>
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: strange effect in eclipse help [message #147021 is a reply to message #146989] Tue, 02 March 2004 12:34 Go to previous messageGo to next message
> multiple windows...
Oups, -remote seems to be working only on unix, sorry...
Give it a try tough, who knows ?
(and it was %1, not %1l of course...)
Re: strange effect in eclipse help [message #147140 is a reply to message #147021] Wed, 03 March 2004 08:17 Go to previous message
>> multiple windows...
Exactly, i had already tried it and it didnt work, btw
thanks for your interest, i'll try the extension
Eric Rizzo suggested in the other post
Norberto
Previous Topic:unicode and eclipse
Next Topic:Code Generation Templates
Current Time: Sat Oct 18 11:07:41 EDT 2025
Powered by FUDForum. Page generated in 0.06064 seconds
