| strange effect in eclipse help [message #146538] |
Mon, 01 March 2004 11:09   |
Eclipse User  |
Originally posted by: nospam.please.com
Hi all,
im using Eclipse and i think it's very very good, but im having
problems with the online help.
When i press F1 the help correctly loads, showing all the stuff
i wanna see BUT if i switch window (i.e. to Eclipse itself or
to another program ) and then come back to the help window, i can
notice a strange graphic corruption.
You can see a sample here
http://utenti.lycos.it/ecio78/messedup.jpg
Im using Eclipse 2.1.2 on Windows 2000 so, does Eclipse
use IE to show up these help pages ? Is the problem related
to MS browser or is there something wrong in my Eclipse ?
Thanks in advance,
Norberto Carnelil
| Re: strange effect in eclipse help [message #146552 is a reply to message #146545] |
Mon, 01 March 2004 11:24    |
Eclipse User  |
Additionnaly, you can look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35009
The last comment includes a workaround
Hope this helps,
Jean
Darin Swanson wrote:
> You are using a version of IE that is not supported.
> IE 5.5 is the minimum required.
> See https://bugs.eclipse.org/bugs/show_bug.cgi?id=34920
> HTH
> Darins
> "Norberto Carnelli" <nospam@please.com> wrote in message
> news:c1vms0$c4l$1@eclipse.org...
>>Hi all,
>>Thanks in advance,
>>Norberto Carnelil
"No brain, no headache"
| Re: strange effect in eclipse help [message #147140 is a reply to message #147021] |
Wed, 03 March 2004 08:17   |
Eclipse User  |
Emmanuel Roubion ha scritto:
> Emmanuel Roubion wrote:
>> According [1] and [2], I would try the following with Mozilla :
>> mozilla -remote openURL(%1l, new-tab)
>> Don't know if it works with Firefox (it should, IMHO)
>> Don't know either which window will open the new tab in case you have
>> multiple windows...
>> [1] http://www.mozilla.org/docs/command-line-args.html
>> [2] http://www.mozilla.org/unix/remote.html
> Oups, -remote seems to be working only on unix, sorry...
> Give it a try tough, who knows ?
> (and it was %1, not %1l of course...)
Exactly, i had already tried it and it didnt work, btw
thanks for your interest, i'll try the extension
Eric Rizzo suggested in the other post
Norberto
FUDForum. Page generated in 0.28102 seconds
