Home » Modeling » GMF (Graphical Modeling Framework) » Label offsets are ignored
Label offsets are ignored [message #146430] Mon, 13 August 2007 11:41 Go to next message
my purpose is to set 2 labels at the end of a connection. One above and
one below the link. To achive this I set negative values for one of the
labels. At the moment it seems that negative offsets are ignored.
I've found some generated code with positive label offsets in a
corresponding view factory. When I set negative values in the gmfgraph
model there is no code generated for label offsets.
Should negative label offsets normally work, or is there another way to
set the label position?
Andreas
Re: Label offsets are ignored [message #146495 is a reply to message #146430] Tue, 14 August 2007 05:25 Go to previous message
Originally posted by: 5d5.mail.ru
I'll check this but there should be no problems with negative values.
I've submitted #199841.
A.Schuster wrote:
> Cheers,
> Andreas
Previous Topic:Generation of copyright statements
Next Topic:How to use image as the diagram element?
Current Time: Sun Jul 27 12:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
