| @Override not working for me [message #146395] |
Mon, 03 April 2006 14:58  |
Originally posted by: eclipse.c3images.com
I just recently switched over to using Java 1.5, and I'm having trouble
with the @Override annotation. Specifically, even though I've set my
compiler compliance level to 5.0, whenever I try to use that annotation I
get an error that says "Type Mismatch: Cannot convert from Override to
Annotation." And this, despite the fact that I'm getting compiler warnings
saying that I'm -not- using @Override in the appropriate locations.
Is there some switch that I haven't turned on?
Thanks very much.
| Re: @Override not working for me [message #147060 is a reply to message #146395] |
Thu, 06 April 2006 16:58  |
Originally posted by: wharley.bea.com
"Greg Maletic" <eclipse@c3images.com> wrote in message
news:9b25efe7ff1c80a85683e475f344f047$1@www.eclipse.org...
I wonder if maybe you are compiling against a 1.4 JRE even though you have
Java 5.0 compiler compliance turned on? Check your JRE classpath container,
in the Java Build Path dialog.
FUDForum. Page generated in 0.09878 seconds
