Some Problem Code in DebugUI Plugins [message #146309] |
Sat, 18 October 2003 15:59  |
Originally posted by: meek77.chollian.net
Debug or Launch Framework provide us to mamke some work.
below code can make some problems.
DebugUITools.launch methods doing launch something in progress dialog.
but
[ dialog.run(true, true, runnable) ] - 15 line
code is something strange.
this make impossible to interactive with workbenchUI.
falks option true make a new thread and this thread not synched with
workbench thread so exception or error (ex.InvocationException) occur when
we operate workbench window.
this code should change like this :
dialog.run(false, true, runnable)
what do you think of this?
public static void launch(final ILaunchConfiguration configuration, final
String mode) {
if (DebugUIPlugin.preLaunchSave()) {
ProgressMonitorDialog dialog = new
ProgressMonitorDialog(DebugUIPlugin.getShell());
IRunnableWithProgress runnable = new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) throws
InvocationTargetException, InterruptedException {
try {
buildAndLaunch(configuration, mode, monitor);
} catch (CoreException e) {
throw new InvocationTargetException(e);
try {
dialog.run(true, true, runnable);
} catch (InvocationTargetException e) {
Throwable targetException = e.getTargetException();
Throwable t = e;
if (targetException instanceof CoreException) {
t = targetException;
if (t instanceof CoreException) {
CoreException ce = (CoreException)t;
IStatusHandler handler =
DebugPlugin.getDefault().getStatusHandler(ce.getStatus());
if (handler != null) {
LaunchGroupExtension group =
DebugUIPlugin.getDefault().getLaunchConfigurationManager().g etLaunchGroup(co
nfiguration, mode);
if (group != null) {
openLaunchConfigurationDialogOnGroup(DebugUIPlugin.getShell( ), new
StructuredSelection(configuration), group.getIdentifier(), ce.getStatus());
return;
DebugUIPlugin.errorDialog(DebugUIPlugin.getShell(),
DebugUIMessages.getString("DebugUITools.Error_1"),
DebugUIMessages.getString("DebugUITools.Exception_occurred_during_launch_2 ")
, t); //$NON-NLS-1$ //$NON-NLS-2$
} catch (InterruptedException e) {
// cancelled
Re: Some Problem Code in DebugUI Plugins [message #146326 is a reply to message #146309] |
Sat, 18 October 2003 18:09  |
I think you should log a bug report against DebugUI with a failing test
case.
Darins
"meeky" <meek77@chollian.net> wrote in message
news:bms608$5k3$1@eclipse.org...
> but
> String mode) {
> try {
> try {
> Throwable t = e;
> nfiguration, mode);
ce.getStatus());
> return;
> // cancelled
FUDForum. Page generated in 0.05569 seconds
