Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem with icon-states in debugger
Problem with icon-states in debugger [message #13582] Tue, 22 July 2008 02:35 Go to next message
Hi...
I'm trying to write a debugger and managed to get something running.
Stepping, suspending, resuming and terminating works fine but if I execute
one of first three actions, the associated buttons are not refreshed until I
re-click the IThread.
The DebugEvents are sent using
DebugPlugin.getDefault().fireDebugEventSet(...) and I ensured the correct
sending with an subsequent System.out.println(event.toString()).
With additional System.out.println's at the canStep...()-methods I saw that
they are only called when I click the IThread, but not after sending the
DebugEvents.
Can anybody tell me how to refresh the button-states right after firing the
DebugEvents?
(Solved) Re: Problem with icon-states in debugger [message #13668 is a reply to message #13582] Tue, 22 July 2008 17:53 Go to previous message
Problem is solved now...
If anybody else has the same problems: It was caused by using the wrong
eventSource. This affects not only the icon-states but also the refreshing
of IThreads and context-view.
(Solved) Re: Problem with icon-states in debugger [message #573991 is a reply to message #13582] Tue, 22 July 2008 17:53 Go to previous message
Previous Topic:Need help with new file wizard and selection
Next Topic:Export Deployable plugins and fragments error: File specified more then once
Current Time: Sat Jul 26 06:00:13 EDT 2025
Powered by FUDForum. Page generated in 0.06974 seconds
