| column initialization order in CTableTree [message #13577] |
Fri, 06 October 2006 13:26  |
Originally posted by: alnospammajor.noboxspamspoon.com
in my usage scenario, the viewer in column x depends on the viewer in
column y (both in the same row). so i need to makes sure the the
initialization of the viewer in column y is completed before column x
needs its values.
what's the best way to achieve this?
al
| Re: column initialization order in CTableTree [message #13621 is a reply to message #13601] |
Sat, 07 October 2006 20:59  |
as expected, this does the trick. but i'm not too happy with it.
Al Major wrote:
> the "obvious" answer is to subclass CTableTreeViewer and override
> doUpdateItem. this seems too heavy handed. is there a better option?
>> needs its values.
>> al
| Re: column initialization order in CTableTree [message #566311 is a reply to message #13577] |
Sat, 07 October 2006 17:26  |
> needs its values.
> al
| Re: column initialization order in CTableTree [message #566339 is a reply to message #13601] |
>> needs its values.
>> al
FUDForum. Page generated in 0.06615 seconds
