Home » Language IDEs » ServerTools (WTP) » empty schemas folder
empty schemas folder [message #145833] Tue, 01 November 2005 17:00 Go to next message
Originally posted by: christopher_brown.engin.com.au
I wrote in earlier when I was unable to connect to an Informix 7.x
database. I've sorted out the connection problem but, after successfully
testing then creating the connection the coresponding schemas folder is
empty.
If I try running SQL I get the following message in the Data Output window
java.sql.SQLException: Database not selected yet.
I've looked at the RDB Tutorial and can see nothing to suggest I've done
something wrong. Any suggestions or advice would be much appreciated.
Chris
Confuded by New Connection wizard ... but okay now [message #146005 is a reply to message #145833] Wed, 02 November 2005 21:34 Go to previous message
Everything is sorted! I'd left the database name out of my connection url,
having assumed the Database field in the New Connection wizard was used to
supply this info.
I'm now connected to an Informix 7.3 database; I can access tables and
views, but the stored procedures are not showing up. Can anyone explain
(or give some indication) why this is?
Chris
Previous Topic:Debug Problems
Next Topic:Scope of Webservice
Current Time: Fri Nov 07 00:54:42 EST 2025
Powered by FUDForum. Page generated in 0.03220 seconds
