| Using m2eclipse for Eclipse plugin projects [message #13562] |
Thu, 24 July 2008 14:18  |
Originally posted by: chris.audley.beaconcs.com
I'd like to use m2eclipse for a plugin project. I'm running Eclipse 3.4
with m2eclipse 0.9.5.20080717-1821.
I've added maven support to the plugin project, and I can see the
correct maven dependencies listed in the 'Maven Dependencies' group.
However, when I try and export some of the java packages from the maven
dependencies using the plugin manifest, I get an error that the packages
don't exist in the plugin project.
When I just list the required jars as 'Referenced Libraries' this works
fine. Is there some setting that I'm missing to enable this? I
couldn't find anything.
Chris
FUDForum. Page generated in 0.05680 seconds
