Home » Archived » Visual Editor (VE) » Setup java visual editor
Setup java visual editor [message #145689] Fri, 30 January 2009 17:19 Go to next message
No Message Body
[Updated on: Tue, 27 October 2009 20:50] by Moderator
Re: Setup java visual editor [message #145699 is a reply to message #145689] Wed, 04 February 2009 20:55 Go to previous messageGo to next message
Hello Cihat,
For Eclipse 3.4, please use Visual Editor 1.4.
Updatesite : http://update.soyatec.org/Ganymede/ve/1.4
I hope thats the resolution for your problem.
Cihat Eldeniz schrieb:
> Hello,
> I have never been able to see the empty form on which you put command
> buttons and other objects. I only see the empty palette. What happened
> was that, when I use the New Visual Class Wizard, I chose Composite
> under SWT and I had already included SWT in the library of the project.
> Right after I finished the selections in the wizard, the builder tried
> to build. It said setup java visual editor and it freezed at 25% and
> after some time "Parse error" appeared in the status bar. If I choose
> Shell rather than Composite [under SWT], then things get somewhat worse;
> it says "Loading..." and it directly gives the "Parse error" afterwards.
> I am writing down the OS and version information and your help in this
> is highly appreciated. Thanks in advance.
> OS: Windows XP Eclipse: 3.4
> Virtual Editor: 1.2
> EMF: 2.4
> GEF: 3.4
> Java EMF Model: 1.2
Re: Setup java visual editor [message #145717 is a reply to message #145699] Thu, 05 February 2009 16:57 Go to previous messageGo to next message
[Updated on: Tue, 27 October 2009 20:51] by Moderator
Re: Setup java visual editor [message #553002 is a reply to message #145689] Sun, 15 August 2010 21:39 Go to previous messageGo to next message
Eclipse Callisto had solved the problem at that time, in case others are experiencing the same problem.
Best.
Re: Setup java visual editor [message #617327 is a reply to message #145689] Wed, 04 February 2009 20:55 Go to previous messageGo to next message
Originally posted by: enricor.eclipse.gmx.de
Hello Cihat,
> Hello,
> Virtual Editor: 1.2
> EMF: 2.4
> GEF: 3.4
> Java EMF Model: 1.2
Re: Setup java visual editor [message #617329 is a reply to message #145699] Thu, 05 February 2009 16:57 Go to previous messageGo to next message
Thank you very much Enrico, I may hopefully try that.
EnricoR wrote:
> Hello Cihat,
>> Hello,
>> Virtual Editor: 1.2
>> EMF: 2.4
>> GEF: 3.4
>> Java EMF Model: 1.2
Re: Setup java visual editor [message #618423 is a reply to message #145689] Sun, 15 August 2010 21:40 Go to previous message
Best.
Previous Topic:Installing VE in Eclipse 3.4.2?
Next Topic:Where are Visual Editor and Visual Class
Current Time: Wed Jul 23 01:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.08174 seconds
