Home » Archived » XML Schema Definition (XSD) » Unmarshalling Problem in eclipse
Unmarshalling Problem in eclipse [message #13549] Thu, 06 March 2003 01:45 Go to next message
Originally posted by: timmerin.singnet.com.sg
Hi, i am trying to unmarshal an xml file using eclipse. but i get the
error:
Unhandled exception caught in event loop.
Reason:
org/exolab/castor/xml/ValidationException
java.lang.NoClassDefFoundError: org/exolab/castor/xml/ValidationException
any idea what could be wrong?
thanks.
Re: Unmarshalling Problem in eclipse [message #13573 is a reply to message #13549] Thu, 06 March 2003 02:15 Go to previous messageGo to next message
Just to add on to my first article, i imported the jar file from
castor.org. And this is the only external jar i'm using outside of the
plugins provided by eclipse.
> error:
> Reason:
> thanks.
Re: Unmarshalling Problem in eclipse [message #13594 is a reply to message #13573] Thu, 06 March 2003 07:58 Go to previous message
Joanie,
This has nothing to do with XSD, so I'm not sure why you are asking this
newsgroup.
This just looks like a classpath problem and I don't even know how you are
running you application. If you are really running it in Eclipse, then every
jar needs to be registered in a plugin.xml. Have a look at how
org.apache.xerces/plugin.xml does this.
> > error:
> > Reason:
> > thanks.
Re: Unmarshalling Problem in eclipse [message #565954 is a reply to message #13549] Thu, 06 March 2003 02:15 Go to previous message
> error:
> Reason:
> thanks.
Re: Unmarshalling Problem in eclipse [message #565994 is a reply to message #13573] Thu, 06 March 2003 07:58 Go to previous message
Joanie,
newsgroup.
> > error:
> > Reason:
> > thanks.
Previous Topic:Unmarshalling Problem in eclipse
Next Topic:Design question about XSD editor
Current Time: Mon Dec 01 05:22:51 EST 2025
Powered by FUDForum. Page generated in 0.04820 seconds
