Home » Language IDEs » ServerTools (WTP) » error while generating the deployment descriptor
error while generating the deployment descriptor [message #145655] |
Sun, 30 October 2005 17:02  |
Originally posted by: alexander.wiesloch.freenet.de
I tried to create und deploy a simple EJB with several Eclipse and WT
versions
( http://www.eclipse.org/webtools/community/tutorials/ejbtutor ial/buildingejbs.html).
My current installation is the Lomboz-Bundle
lomboz-eclipse-emf-gef-jem-3.1RC2.zip.
My annotation provider is Xdoclet 1.2.3. In all cases an error occurred
while generating the deployment descriptor:
--------Error------------
The content of element type "ejb-jar" must match
" (description?,display-name?,small-icon?,large-icon?,enterpri se-beans,relationships?,assembly-descriptor?,ejb-client-jar? ) ".
Furthermore the other classes were never generated. (TigerHome, TigerLocal
further particulars:
Win XP
jsdk 1.4.2_09
Thank you for your help
Peter
Re: error while generating the deployment descriptor [message #146490 is a reply to message #145655] |
Tue, 08 November 2005 00:53   |
Originally posted by: sachin1618.gmail.com
I'm having the same problem using Eclipse 3.1 and WTP 0.7 Final. I think it
has something do with using JDK 5.0 with Xdoclet 1.2.3. Even turning the
validation off doesn't help. No bean classes are been generated, nor any
error messages are displayed.
Does anyone know what the problem is?
"Peter Alexander" <alexander.wiesloch@freenet.de> wrote in message
news:op.szhbi4zgt9ut3i@winxp...
> Hello,
> versions
> Win XP
> jsdk 1.4.2_09
> Peter
Re: error while generating the deployment descriptor [message #146571 is a reply to message #146490] |
Tue, 08 November 2005 14:11  |
On Tue, 08 Nov 2005 06:53:11 +0100, ThirdIon <sachin1618@gmail.com> wrote:
Hello ThirdIon
I have tried a lot of configurations to solve this problem.
In some reasons the tempAnt.xml in
(<your workspace>
..metadata\.plugins\org.eclipse.jst.j2ee.ejb.annotations.xdo clet\tempAnt.xml)
will never exectue from ant.This script will generate the Classes.
Now I execute this tempAnt.xml manually with an externalTool -
configuration.
################################### My externalTool - configuration
<launchConfiguration type="org.eclipse.ant.AntLaunchConfigurationType">
<stringAttribute key="process_factory_id"
value="org.eclipse.ant.ui.remoteAntProcessFactory"/>
<booleanAttribute key="org.eclipse.ant.ui.DEFAULT_VM_INSTALL"
value="true"/>
<booleanAttribute key="org.eclipse.jdt.launching.DEFAULT_CLASSPATH"
value="false"/>
<stringAttribute key="org.eclipse.jdt.launching.MAIN_TYPE"
value="org.eclipse.ant.internal.ui.antsupport.InternalAntRunner "/>
<listAttribute key="org.eclipse.debug.ui.favoriteGroups">
<listEntry value="org.eclipse.ui.externaltools.launchGroup"/>
</listAttribute>
<stringAttribute key="org.eclipse.debug.ui.ATTR_CAPTURE_IN_FILE"
value="${workspace_loc:/PeterTest}"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables"
value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.CLASSPATH_PROVIDER"
value="org.eclipse.ant.ui.AntClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER"
<stringAttribute key="org.eclipse.jdt.launching.VM_INSTALL_TYPE_ID"
value="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType "/>
<stringAttribute key="org.eclipse.jdt.launching.VM_INSTALL_NAME"
value="j2sdk1.4.2_09"/>
<listAttribute key="org.eclipse.jdt.launching.CLASSPATH">
<listEntry value="<?xml version="1.0"
encoding="UTF-8"?> < runtimeClasspathEntry
type="4" path="1"
containerPath="org.eclipse.jdt.launching.JRE_CONTAI NER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMTyp e/j2sdk1.4.2_09"/> "/>
type="2" path="3"
externalArchive="C:/JAVA_STUFF/J2ee/j2ee1.4/lib/j2e e.jar"/> "/>
id="org.eclipse.ant.ui.classpathentry.antHome&q uot;> <memento
default="true"/> </r untimeClasspathEntry> "/>
id="org.eclipse.ant.ui.classpathentry.extraClasspat hEntries"> <memento/>& amp;#10;</runtimeClasspathEntry> "/>
</listAttribute>
<stringAttribute key="org.eclipse.ui.externaltools.ATTR_LOCATION"
value="C:\Dokumente und Einstellungen\JavaDev\Eigene
Dateien\Projekte\WORKSPACES\Lomboz\.metadata\.plugins\org.ec lipse.jst.j2ee.ejb.annotations.xdoclet\tempAnt.xml "/>
</launchConfiguration>
Its important to add j2ee.jar to the externalTool-configuration
1. Set a jsdk e.g. 1.4.2
2. Make a new e.g EJB-Project, choose an server, set xdoclet (3.1.2)
3. -> now a new project with ejb-jar.xml and other specific files were
generated.
The ejb-jar.xml is not valid. Nevertheless, in this situation it is
correct.After the generation of the other files with tempAnt.xml you will
find now a lot of new rows with several ejb-specific information in the
ejb-jar.xml.
Now the file is valid.
If there a problem with the generation you will get detailed information
in the console-view.
####################### Log on console view while execute tempAnt.xml
Buildfile: C:\Dokumente und Einstellungen\JavaDev\Eigene
init:
ejbdoclet:
[ejbdoclet] (XDocletMain.start 47 ) Running
<dataobject/>
[ejbdoclet] (XDocletMain.start 47 ) Running <dao/>
<valueobject/>
<utilobject/>
[ejbdoclet] Generating Util class for 'test.MyBean'.
Some combinations of jsdk ( jsdk1.4.2.x, 1.5.x) , eclipse-versions ( 3.1,
3.11, 3.1M1, 3.1M2, Lomboz, Jboss 1.5 r1), webtools (0.7, 0.71, 1.0M8,
spezific Lomboz extensions, Jboss-extensions .. .) and some other dark
horses does not work properly for specific circumstances.
My working configuration:
-WinXP prof.
-Eclipse SDK
Version: 3.1.0
Build id: I20050811-1530 -> 3.1M1
-wt1.0 M8 and the required gef, sdk, emf .. see
http://download.eclipse.org/webtools/downloads/drops/S-1.0M8 -200509230840/
-Geronimodriver 0.5 see http://geronimo.apache.org/devtools/index.html
-jsdk 1.4.2_09
-xdoclet 3.2.1
-Jboss 3.2.3
-Geronimo 1.0M5
Regards Peter
> it
>> Hello,
>> versions
>> TigerLocal
>> Win XP
>> jsdk 1.4.2_09
>> Peter
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Current Time: Sat Jul 19 10:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.34176 seconds
