Home » Language IDEs » C / C++ IDE (CDT) » prevent *.o file appear under a folder in project view
prevent *.o file appear under a folder in project view [message #145598] Wed, 18 May 2005 06:05 Go to next message
Originally posted by: qwejohn.hotmail.com
I am using Eclipse 3.1 M6 with CDT.
I created a standard C project.
I created folders insilde that project (By right click->New->New Folder
(not New Source Folder).
Now: when I add "c" files into it (by right click->New File) and build
them , the *.o that are created appear in the left pane (Project
View it is called if I am not wrong) under the folder where the *.c
files are.
Is there a way to prevent it ?
Or should I simply write my makefile
so that the *.o files will be
put in a different folder than the *.c files
which are their input?
Cheer,
John
Re: prevent *.o file appear under a folder in project view [message #145616 is a reply to message #145598] Wed, 18 May 2005 08:09 Go to previous messageGo to next message
Originally posted by: jonas.nightmode.org
Click on the little arrow in the top-right of the browser, select
"Filters" and tell it to exclude object-files and you should be set.
John Que wrote:
> Hello,
> files are.
> Cheer,
> John
Re: prevent *.o file appear under a folder in project view [message #145640 is a reply to message #145616] Wed, 18 May 2005 09:01 Go to previous messageGo to next message
I open the "filters" dialog;
The only thing I see there is:
Select the filters to apply(matching files will be
hidden)
*.class
can I somehow cause *.o files to appear in this
list (my project is a C projet; *.class files are
irrelvant here).
Sting
Re: prevent *.o file appear under a folder in project view [message #145658 is a reply to message #145640] Wed, 18 May 2005 09:20 Go to previous message
You need to show the "C/C++ Projects" view and not the "Navigator" view
for it to work, but that should be default when using the C/C++
Perspective.
Previous Topic:target file lock up
Next Topic:Can I add my naming convention rules to the CDT parser?
Current Time: Tue Nov 04 10:19:00 EST 2025
Powered by FUDForum. Page generated in 0.23812 seconds
