Home » Language IDEs » C / C++ IDE (CDT) » target file lock up
target file lock up [message #145561] Wed, 18 May 2005 01:32 Go to next message
Each time I select "build all" the final executable is locked up. So for the
next build I have to close and reopen the project.
How can I fix this? I am using mingw and msys.
ben
Re: target file lock up [message #145571 is a reply to message #145561] Wed, 18 May 2005 02:35 Go to previous messageGo to next message
Hi Ben,
I use the same environment but don't have the same problem. Can you post
your Eclipse and CDT versions as well as the total procedure.
I had it a number of times that the debug closure would not close the
exectuable and subsequently lock it. Could that be related?
Stefan
Re: target file lock up [message #145630 is a reply to message #145571] Wed, 18 May 2005 08:35 Go to previous message
> Hi Ben,
My Eclipse version is 3.0.2, CDT version 2.1.1
The procedure is simple save all header and source files, then
project->build all
I didn't run the debugger although I did run the program itself.
ben
> Stefan
Previous Topic:Managing projects
Next Topic:prevent *.o file appear under a folder in project view
Current Time: Tue Jul 22 00:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.02316 seconds
