Home » Language IDEs » ServerTools (WTP) » Lastest usable build ?
Lastest usable build ? [message #145514] Fri, 28 October 2005 09:40 Go to next message
Originally posted by: cooll.free.fr
Hi !
which is the latest usable build to develop web projects and deploy them on
tomcat ?
M8 has a problem with automatic deployments which make it quite unusable.
wtp-I20051015 can't publish to tomcat any project that has a file under src
dir.
wtp-I20051021 seems unable to create a web project:
java.lang.ClassCastException:
org.eclipse.jst.j2ee.web.project.facet.WebFacetInstallConfig
org.eclipse.jst.servlet.ui.project.facet.WebFacetInstallPage .setConfig(WebFa
cetInstallPage.java:118)
org.eclipse.wst.common.project.facet.ui.AddRemoveFacetsWizar d.handleSelected
FacetsChangedEvent(AddRemoveFacetsWizard.java:347)
I'll try 0.7.1 but I read here that it has some problems.
Thanks.
Re: Lastest usable build ? [message #145538 is a reply to message #145514] Fri, 28 October 2005 12:06 Go to previous messageGo to next message
Lionel wrote:
> Hi !
> them on tomcat ?
with wtp-I20051028, dependant project are not copied to web-inf/lib anymore,
and after restarting eclipse, web project are not recognised as web project,
so they can't be deployed to the server :(
Re: Lastest usable build ? [message #145716 is a reply to message #145538] Mon, 31 October 2005 13:12 Go to previous messageGo to next message
Originally posted by: neale.likemynds.com
Hi Lionel,
There's some migration required. There are some subtle differences
between what goes in .project and .wtpmodules between the two releases.
There's no automatic project migration.
What would be nice is to be able to "Add WTP Nature" to an existing
project though...
Neale
Lionel wrote:
> Lionel wrote:
>>Hi !
>>them on tomcat ?
Re: Lastest usable build ? [message #145735 is a reply to message #145716] Mon, 31 October 2005 14:21 Go to previous message
Originally posted by: rsanheim.REMOVE.gmail.com
Neale wrote:
> Hi Lionel,
> project though...
> Cheers,
> Neale
I believe there are plans for migrations to happen at some point, but
its not there in the latest I build. Also, you have to republish on any
jsp/html changes and hotswap doesn't work. At this point I would call
the I builds usable but annoying for typical web dev work, if you know
how to manually migrate projects.
- Rob
http://www.robsanheim.com
Previous Topic:Where is org.eclipse.webbrowser ?
Next Topic:make changes to jsp while debugging
Current Time: Tue Dec 02 12:50:58 EST 2025
Powered by FUDForum. Page generated in 0.30265 seconds
