Home » Eclipse Projects » Buckminster dev » [buckminster-dev] How can I build a plugin eclipse in order to get at the end a jar that contains th
[buckminster-dev] How can I build a plugin eclipse in order to get at the end a jar that contains th [message #13523] Fri, 28 March 2008 07:53 Go to next message
Originally posted by: ikalboussi.ilog.fr
------_=_NextPart_001_01C890CA.48CF6082
Content-Type: text/plain;
charset="US-ASCII"
Thanks Matt
=20
=20
I've solved my problem by following your instructions carefully because
when I've posted the other message I've jumped your last instruction
=20
Now, I've a new question: How can I build a plugin eclipse in order to
get at the end a jar that contains the plugin and all its
dependencies?
=20
=20
=20
Content-Type: text/html;
charset="US-ASCII"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Thanks Matt<o:p></o:p></span></font></p>
font-family:Arial'><o:p>&nbsp;</o:p></span></font></p >
font-family:Arial'>I&#8217;ve solved my problem by following your =
because when I&#8217;ve posted the other message I&#8217;ve jumped your =
last
instruction<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DWingdings><span =
font-family:Wingdings'>J</span></font><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span ></font></p=
font-family:Arial'>Now, I&#8217;ve a new question: How can I build a =
plugin
eclipse &nbsp;in order to get at the end a jar that contains &nbsp;the =
plugin &nbsp;and
all its dependencies?<o:p></o:p></span></font></p>
font-family:Arial'>Thanks<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C890CA.48CF6082--
Re: [buckminster-dev] How can I build a plugin eclipse in order to get at the end a jar that contain [message #13547 is a reply to message #13523] Fri, 28 March 2008 08:17 Go to previous message
Hi Imen,
could please be more specific? I am not sure if I understand what you
would like to create. It would be ideal if you described an example of it.
Thank you.
Best regards
Filip Hrbek
Imen Kalboussi wrote:
> Thanks Matt
> I’ve solved my problem by following your instructions carefully because
> when I’ve posted the other message I’ve jumped your last instruction
> J
> Now, I’ve a new question: How can I build a plugin eclipse in order to
> get at the end a jar that contains the plugin and all its dependencies?
> Thanks
Previous Topic:[buckminster-dev] (no subject)
Next Topic:RE: [buckminster-dev] (no subject)
Current Time: Tue Jul 22 12:05:20 EDT 2025
Powered by FUDForum. Page generated in 0.05784 seconds
