Home » Archived » Visual Editor (VE) » Genereta XML file with VE
Genereta XML file with VE [message #145485] Mon, 01 December 2008 19:03 Go to next message
i'm trying to generate a XML file with VE but i can only generate Java
source. How can i generate XML file?
Re: Genereta XML file with VE [message #145494 is a reply to message #145485] Mon, 01 December 2008 21:17 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
What's in your XML file?
Have you looked at any of the Modeling projects related to codegen? EMF,
JET, TMF... ?
http://www.eclipse.org/modeling/
burak celen wrote:
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: Genereta XML file with VE [message #145517 is a reply to message #145494] Fri, 05 December 2008 11:45 Go to previous messageGo to next message
In my XML file i keep the information about the which widgets use and
their information.My XML file like
<jframe>
<jpanel>
<jbutton>
<position>100 80</position>
<width>10</width>
<height10<height>
</jbutton>
</jpanel>
</jfram>
Normally ve generate Java file but i don't want it.I want to generate XML
file instead of Java file.
Re: Genereta XML file with VE [message #145530 is a reply to message #145517] Fri, 05 December 2008 14:24 Go to previous messageGo to next message
If there's a schema or data model for that XML file, you could
potentially set up some sort of transform from .java to .xml; AFAIK VE
is backed by EMF, so you should be able to use that underlying model
framework to do some sort of model-to-model transform.
Perhaps asking in #eclipse-modeling on IRC or in one of the modeling
newsgroups would help? I'll copy this to EMF, M2M and M2T.
Failing the above, this sounds like a feature request for the VE project
-- "export to xml" or "transform java editor to XML representation".
Nick
burak celen wrote:
> <jframe>
> <jpanel>
> <jbutton>
> <width>10</width>
> <height10<height>
> </jbutton>
> </jpanel>
> </jfram>
> XML file instead of Java file.
Re: Genereta XML file with VE [message #145647 is a reply to message #145485] Mon, 12 January 2009 06:59 Go to previous message
The generattion of XML UI is not supported in VE. I have worked on a project
for one of customers http://www.soyatec.com/services/vex-ccr.png.
I should say it is not an easy job. If you need help, please contact me.
Best regards
Yves YANG
soyatec yves.yang@soyatec.com
"burak celen" <celenburak@gmail.com> wrote in message
news:799e3b9392d4fad3ce28c7f4e56b0f00$1@www.eclipse.org...
Re: Genereta XML file with VE [message #617305 is a reply to message #145485] Mon, 01 December 2008 21:17 Go to previous message
JET, TMF... ?
burak celen wrote:
Re: Genereta XML file with VE [message #617307 is a reply to message #145494] Fri, 05 December 2008 11:45 Go to previous message
<jframe>
<jpanel>
<jbutton>
<width>10</width>
<height10<height>
</jbutton>
</jpanel>
</jfram>
Re: Genereta XML file with VE [message #617308 is a reply to message #145517] Fri, 05 December 2008 14:24 Go to previous message
Nick
burak celen wrote:
> <jframe>
> <jpanel>
> <jbutton>
> <width>10</width>
> <height10<height>
> </jbutton>
> </jpanel>
> </jfram>
Re: Genereta XML file with VE [message #617321 is a reply to message #145485] Mon, 12 January 2009 06:59 Go to previous message
Best regards
Yves YANG
Previous Topic:palette in visual editor
Next Topic:palette Component on Visual editor
Current Time: Tue Jul 22 01:54:28 EDT 2025
Powered by FUDForum. Page generated in 0.20457 seconds
