Home » Language IDEs » C / C++ IDE (CDT) » debugging curses
debugging curses [message #145442] Sat, 14 May 2005 04:38 Go to next message
Originally posted by: Wolfram.Koehn.gmx.net
Is there a way to debug a curses program with eclipse on linux ?
If I set the environment variable "TERM" to "xterm" i can get it
running, but unfortunately the console doesn't undesstand the
control-sequences and displays garbage.
Wolfram
Re: debugging curses [message #145474 is a reply to message #145442] Sat, 14 May 2005 11:33 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
Use the "attach to running program" option.
"Wolfram Koehn" <Wolfram.Koehn@gmx.net> wrote in message
news:d64kvu$7t1$1@news.eclipse.org...
> Wolfram
Re: debugging curses [message #145491 is a reply to message #145474] Sun, 15 May 2005 05:41 Go to previous message
That's it !! One only has to change to "Attach to Local Application"
instead of "Local Application" in the debug-configuration-window and an
other program can be fully remote-controlled.
Thanks a lot !
>>Wolfram
Previous Topic:Creating Forms
Next Topic:multi-target projects with CDT
Current Time: Fri Nov 21 23:30:11 EST 2025
Powered by FUDForum. Page generated in 0.02836 seconds
