Home » Archived » Visual Editor (VE) » Problem with Visual Edito installing
Problem with Visual Edito installing [message #145366] Thu, 09 October 2008 06:28 Go to next message
Hej!
I have installed both Eclipse SDK and Visual editor from this page.
I install firts Eclipse and efter it i extract the visual editor zip files
in the same map the the Eclipse is.
In the help when I check help/about Eclipse SDk/Feature Detalils I can see
that I have org.eclipse.ve and org.ecliipse.ve.sdk and
org.eclipse.ve.source.
But when I want creat a class for example I can not choos Visual Class.
What it is that I do wrong?
I have now installed eclipse 3.2.
Best regards
Akram
Re: Problem with Visual Edito installing [message #145370 is a reply to message #145366] Sun, 12 October 2008 02:21 Go to previous message
Originally posted by: codeslave.ca.ibm.com
What page? What version of VE? What JDK vendor/version? What operating
system? What map?
See http://wiki.eclipse.org/VE/Installing
Nick
akram wrote:
> Hej!
> files in the same map the the Eclipse is.
> see that I have org.eclipse.ve and org.ecliipse.ve.sdk and
> Best regards
> Akram
Re: Problem with Visual Edito installing [message #617291 is a reply to message #145366] Sun, 12 October 2008 02:21 Go to previous message
system? What map?
Nick
akram wrote:
> Hej!
> Best regards
> Akram
Previous Topic:Problem with Visual Edito installing
Next Topic:IVEContributor1 pallete erasing problem
Current Time: Sun Nov 30 03:13:39 EST 2025
Powered by FUDForum. Page generated in 0.03568 seconds
