Home » Newcomers » Newcomers » Java Editor Puts Certain Things In Italics
Java Editor Puts Certain Things In Italics [message #145348] Tue, 28 March 2006 16:56 Go to next message
Originally posted by: larry.stupidtuesday.com
I type in the following code:
HelloService proxy =
HelloService)Registry.lookup(WSDL_URL,HelloService.class);
System.out.println(proxy.hello("world"));
After I am done typing the editor goes through and italicizes the
following 3 items:
WSDL_URL
..lookup
..out
Why is it doing this and how can I shut it off?
I looked through Window > Preferences > Java > Code Style and can't find
a setting to control this.
Larry
Re: Java Editor Puts Certain Things In Italics [message #145354 is a reply to message #145348] Tue, 28 March 2006 21:45 Go to previous messageGo to next message
Originally posted by: panajotis.freemail.gr
These methods/members are in italics to indicate that they are static.
Personally I love this feature, but since you don't you can switch it off
by going to:
Preferences > Java > Editor > Syntax Coloring.
From the Element list select the "static fields" and "static method
invocations".
Uncheck the "italics" checkbox and you're done.
Re: Java Editor Puts Certain Things In Italics [message #145439 is a reply to message #145354] Wed, 29 March 2006 07:35 Go to previous message
Thanks a bunch, pana!
> off by going to:
> invocations".
Previous Topic:Creating plugin for test management and automation of boards
Next Topic:Howto "extend" enumerations
Current Time: Thu Nov 06 16:30:45 EST 2025
Powered by FUDForum. Page generated in 0.08019 seconds
