| JRE 1.5 problem [message #145315] |
Tue, 28 March 2006 01:41  |
Originally posted by: another_newbie.xxxxxxxx.com
I'm a completely new user, so i'd appreciate anyone's helpful comments.
I've just installed eclipse 3.1.2 on my win98 machine, which already has
java 1.5 installed. Compiling and running scripts written with a text
editor works fine. Eclipse.exe however won't run at all. I just get an
dialogue box saying that java 1.4.1 is required, current version 1.4.0_01
Sun's website says that java 1.5 should run with programmes designed for
older versions. Has anyone come across this problem, or have any idea how
to fix it?
cheers,
dan
| Re: JRE 1.5 problem [message #145961 is a reply to message #145315] |
Fri, 31 March 2006 09:06  |
Daniel,
Have a look at your system path and see if a product you have installed
may have also installed a JRE of its own and put a mention of it in the
system path.
The Oracle database client is notorious for doing this.
In almost all cases you can remove BOTH the path entry AND the offending
JRE supplied by the product, and your current JRE will work in 99.999%
of cases.
Chris
FUDForum. Page generated in 0.28503 seconds
