Home » Newcomers » Newcomers » JRE 1.5 problem
JRE 1.5 problem [message #145315] Tue, 28 March 2006 01:41 Go to next message
Originally posted by: another_newbie.xxxxxxxx.com
I'm a completely new user, so i'd appreciate anyone's helpful comments.
I've just installed eclipse 3.1.2 on my win98 machine, which already has
java 1.5 installed. Compiling and running scripts written with a text
editor works fine. Eclipse.exe however won't run at all. I just get an
dialogue box saying that java 1.4.1 is required, current version 1.4.0_01
Sun's website says that java 1.5 should run with programmes designed for
older versions. Has anyone come across this problem, or have any idea how
to fix it?
cheers,
dan
Re: JRE 1.5 problem [message #145821 is a reply to message #145315] Thu, 30 March 2006 14:15 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Daniel wrote:
> how to fix it?
This question is asked and answered a lot - please try searching the
past messages before posting questions.
The short answer is that Eclipse is finding the older JRE on your system
- you need to tell it explicitly which version to use. Here is a page
that explains the details: http://eclipsewiki.editme.com/StartupProblems
Hope this helps,
Eric
Re: JRE 1.5 problem [message #145961 is a reply to message #145315] Fri, 31 March 2006 09:06 Go to previous message
Daniel,
Have a look at your system path and see if a product you have installed
may have also installed a JRE of its own and put a mention of it in the
system path.
The Oracle database client is notorious for doing this.
In almost all cases you can remove BOTH the path entry AND the offending
JRE supplied by the product, and your current JRE will work in 99.999%
of cases.
Chris
Previous Topic:Eclipse framework with multiple plugin support
Next Topic:Compare project with directory
Current Time: Sat Jul 26 06:46:04 EDT 2025
Powered by FUDForum. Page generated in 0.12333 seconds
