Home » Eclipse Projects » DTP » DTP 0.9RC2 "Error loading driver instance data"
DTP 0.9RC2 "Error loading driver instance data" [message #13499] Mon, 08 May 2006 18:45 Go to next message
I am unsuccessfully attempting to create a driver definition for Sybase
12.x on Win2K using DTP 0.9RC2. The following error appears in the log:
org.eclipse.datatools.connectivity
!MESSAGE Error loading driver instance data.
!STACK 1
org.eclipse.core.runtime.CoreException: Error loading driver instance data.
org.eclipse.datatools.connectivity.drivers.XMLFileManager.lo adPropertySets(XMLFileManager.java:228)
SAXParseException: Invalid encoding name "UTF8".
org.eclipse.datatools.connectivity.drivers.XMLFileManager.lo adPropertySets(XMLFileManager.java:207)
Any help is appreciated.
- Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #13583 is a reply to message #13499] Tue, 09 May 2006 09:56 Go to previous messageGo to next message
Originally posted by: jograham.sybase.com
Hi Ron,
I think this is the same issues as found in:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=140280
We'll be looking into this. BTW, what locale is your machine setting?
John Graham
Eclipse Data Tools Platform PMC Chair
"R. Gavlin" <rgavlin@yahoo.com> wrote in message
news:8c0cdb8b5431220a078ade699b02d974$1@www.eclipse.org...
> !STACK 1
> data.
> at
> at
> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #13664 is a reply to message #13583] Tue, 09 May 2006 12:11 Go to previous messageGo to next message
John,
Please see my comments in the bug.
Is there a way to workaround this problem by manually editing
driverStorage.xml?
- Ron
John Graham wrote:
> Hi Ron,
> John Graham
>> !STACK 1
>> data.
>> at
>> at
>> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #13685 is a reply to message #13664] Tue, 09 May 2006 16:25 Go to previous messageGo to next message
Hi Ron,
Yes, you could remove the "encoding" attribute, and that might help. We've
been talking among ourselves, trying to get this to repro on the dev
machines. No luck yet (and I did add Xerces into the mix), but the latest
theory has to do with the JVM. Seems to be failing on IBM JVM but not on Sun
JVM. Which one are you using?
John Graham
news:022b40cfe585557abe12ca872ada6768$1@www.eclipse.org...
> John,
> driverStorage.xml?
> - Ron
> John Graham wrote:
>> Hi Ron,
>> Regards,
>> John Graham
>>> !STACK 1
>>> data.
>>> at
>>> at
>>> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #13745 is a reply to message #13685] Tue, 09 May 2006 21:22 Go to previous message
I'm using Sun JDK 1.4.2_08 on win2k.
Re: DTP 0.9RC2 "Error loading driver instance data" [message #574421 is a reply to message #13499] Tue, 09 May 2006 09:56 Go to previous message
Hi Ron,
John Graham
> !STACK 1
> data.
> at
> at
> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #574524 is a reply to message #13583] Tue, 09 May 2006 12:11 Go to previous message
John,
driverStorage.xml?
- Ron
John Graham wrote:
> Hi Ron,
> John Graham
>> !STACK 1
>> data.
>> at
>> at
>> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #574573 is a reply to message #13664] Tue, 09 May 2006 16:25 Go to previous message
Hi Ron,
John Graham
> John,
> driverStorage.xml?
> - Ron
> John Graham wrote:
>> Hi Ron,
>> Regards,
>> John Graham
>>> !STACK 1
>>> data.
>>> at
>>> at
>>> - Ron
Re: DTP 0.9RC2 "Error loading driver instance data" [message #574674 is a reply to message #13685] Tue, 09 May 2006 21:22 Go to previous message
Previous Topic:Relative path for JAR location
Next Topic:Batch ddl generation?
Current Time: Fri Jul 25 23:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.05623 seconds
