Home » Language IDEs » Java Development Tools (JDT) » Announce: new plug-in for continuous testing
Announce: new plug-in for continuous testing [message #145134] Tue, 24 February 2004 22:28 Go to next message
All,
For the last year, I have been researching the idea of continuous
testing. Continuous testing builds on the automated developer support
in Eclipse to make it even easier to keep your Java code well-tested, if
you have a JUnit test suite. With continuous testing enabled, as you
edit your code, Eclipse runs your tests quietly in the background, and
notifies you if any of them fail or cause errors. It is most useful in
situations where you would already have a test suite while you are
changing code: when performing maintenance, refactoring, or using
test-first development.
Continuous testing builds on the following features of Eclipse:
* JUnit integration: Test suites run under continuous testing give
you the same information, in the same format, that you already get from
Eclipse's JUnit integration. However, continuous testing also helps to
automate the choice of when to run tests, which tests to run, and in
which order.
* Compile error notification: As soon as you write code that
contains a compilation error, Eclipse highlights the error in the text
and the margin, and creates a task in the Problems table. This makes it
easy both to quickly find out if what you wrote was wrong, and to step
through and fix problems in an orderly fashion. With continuous testing,
you get the same kind of notification when you write or edit code that
causes one of your tests to fail. However, test failures are different
from compile errors in several ways: test failures can sometimes not
easily be tracked to a single line of code, and test failures also can
provide more information, such as a backtrace, than compile errors.
We have implemented a plug-in that implements continuous testing in
Eclipse. This plug-in is similar to intent to the one developed in
Erich Gamma and Kent Beck's _Contributing to Eclipse_. Gamma and Beck's
plug-in includes an editor for excluding tests from automatic execution.
Ours includes asynchronous test execution through the build framework,
detailed specification of the launch configuration and environment for
automatic tests, test prioritization, and other enhancements. For
installation instructions, documentation, and further information on my
research, please see
http://pag.csail.mit.edu/~saff/continuoustesting.html
To comment and vote on this feature as an enhancement to Eclipse, please
visit
https://bugs.eclipse.org/bugs/show_bug.cgi?id=51292
Thank you for your time,
David Saff
Re: Announce: new plug-in for continuous testing [message #145150 is a reply to message #145134] Wed, 25 February 2004 03:58 Go to previous messageGo to next message
>This plug-in is similar to intent to the one developed in ... _Contributing
to Eclipse_.
David is too shy here <g> This work goes way beyond what we did in the book.
Definitely worth to give it a try and to provide feedback in the bug report
referred to below.
--erich
"David Saff" <saff@mit.edu> wrote in message
news:c1h4f7$4mc$1@eclipse.org...
> All,
> which order.
> visit
> David Saff
Re: Announce: new plug-in for continuous testing [message #145446 is a reply to message #145134] Wed, 25 February 2004 13:27 Go to previous message
Interesting. AFAIR 2 years ago there were a discussion on this
newsgroup (ok eclipse.tools then) about such a feature.
Ah knew it, the br#
https://bugs.eclipse.org/bugs/show_bug.cgi?id=12167
It could be marked resolved when Davids plugin gets into jdt ;).
It seems working in my M7 ibuild.
To install you need at least a 3.0 M6 version. Instruction at
http://pag.csail.mit.edu/~saff/eclipse_doc/install.html
even a short tutorial to get started fast is there.
martin
Previous Topic:Modeling Information about JDT plug-in needed for making an extension of JDT
Next Topic:External Tool/Ant Builders
Current Time: Sun Aug 31 09:50:28 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
