Home » Language IDEs » ServerTools (WTP) » XDoclet Configurations
XDoclet Configurations [message #145095] Tue, 25 October 2005 07:52 Go to next message
Originally posted by: pschmidiger.gmail.com
I have a problem with some java-classes, which are generated by wtp from a
SessionBean.
<h2>My Environment:<h2>
- Eclipse-3.1
- wtp-0.7M8
<h2>Initial position:<h2>
I create a SessionBean named <b>ConverterBean<b>. This follow Code is the
XDoclet-Definition from the ConverterBean.
<code>
* A generated session bean
* <!-- end-user-doc -->
* <!-- begin-xdoclet-definition -->
* @ejb.bean name="Converter"
* description="A session bean named Converter"
* display-name="Converter"
* jndi-name="Converter"
* type="Stateless"
* transaction-type="Container"
* @ejb.env-entry
* name="param/euroDollar"
* type="java.lang.String"
* value="0.8"
* @ejb.util
* generate="false"
* <!-- end-xdoclet-definition -->
* @generated
</code>
I write a Business Mehtod with the view-type both:
<code>
* Business method
* @ejb.interface-method view-type = "both"
public double dollarToEuro(double dollar) {
</code>
<h2>Result of XDoclet-Generation, the follow java-class-files:<h2>
- Converter
- ConverterHome
- ConverterLocal
- ConverterLocalHome
- ConverterSession
<h2>!!!Problem!!!:<h2>
It generate a class named <b>ConverterSession</b>. I don't need this
class. How can I disable this generated class? Can I configure the
XDoclet-Builder (like JBoss-IDE)?
Thanks for your answer!
Pascal
Re: XDoclet Configurations [message #146787 is a reply to message #145095] Thu, 10 November 2005 12:49 Go to previous message
Anyone know how to solve this?
Previous Topic:NullPointerException JSEditor
Next Topic:Cleanup Document on popup menu in StructuredTextEditor missing???
Current Time: Fri Nov 07 22:13:52 EST 2025
Powered by FUDForum. Page generated in 0.03731 seconds
