Home » Modeling » GMF (Graphical Modeling Framework) » Compartment loosing hover ListLayout=false
Compartment loosing hover ListLayout=false [message #145079] Wed, 01 August 2007 10:30 Go to next message
hi all,
I got a strange problem:
I'm loosing the "add-element" of the child-reference of an compartment
when I switch ListLayout to false in gmfGen (I'm loosing it in the
speach-balloon which appreas as an hover effect of the comparment
containing element). I guess this is because the editor doesn't know
where to put the newly created element when its comparment isn't
ListLayout. Can I somehow specify a default location e.g. to add it to
the center of the current viewport of the compartment?
-stefan
Re: Compartment loosing hover ListLayout=false [message #148761 is a reply to message #145079] Sun, 02 September 2007 16:59 Go to previous message
Hi Stefan,
do you have the described problem while using the following
configuration?- The parent figure of the compartment specifies a XY
Layout.
- The ListLayout attribute of the compartment is set to false.
If so, you have the same problem as me. Did you solve the problem?
See the "Compartment with special characteristics" post for a
follow-up.
Nicolai
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Previous Topic:How to deploy a gmf plugin?
Next Topic:Taipan Example Models
Current Time: Fri Jul 25 21:59:07 EDT 2025
Powered by FUDForum. Page generated in 0.03109 seconds
