Can you make Eclipse not display files with certain extension in Java perspective? [message #144998] |
Tue, 24 February 2004 11:57  |
Originally posted by: guleyupoglu.hotmail.com
------=_NextPart_000_002B_01C3FACD.679DF270
Content-Type: text/plain;
charset="iso-8859-1"
Subject says it all but my problem is that I use Rational (IBM) Rose to =
generate code and it generates backup files with *.jv~ extension where =
it replaces my *.java files. So for each *.java file I have one of =
those and it makes the file list very crowded as you can imagine.
I would appreciate any suggestion. Note that I did not find a way to =
tell Rose to generate the backup files in a different folder outside my =
development area.
Thanks.
Suleyman
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Subject says it all but my problem is =
that I use=20
Rational (IBM) Rose to generate code and it generates backup files with =
*.jv~=20
extension where it replaces my *.java files. So for each *.java =
file I=20
have one of those and it makes the file list very crowded as you can=20
imagine.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I would appreciate any =
suggestion. Note that=20
I did not find a way to tell Rose to generate the backup files in a =
different=20
folder outside my development area.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks.</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>--<BR>Suleyman</FONT></DIV></BODY></HTML>
------=_NextPart_000_002B_01C3FACD.679DF270--
Re: Can you make Eclipse not display files with certain extension in Java perspective? [message #145052 is a reply to message #145026] |
Tue, 24 February 2004 13:59  |
Great help. Thank you very much!
Suleyman
"Eric Rizzo" <eclipse-user@jibeinc.com> wrote in message
news:c1g14k$pbp$1@eclipse.org...
> Two suggestions:
> 1) Try selecting Filters... from the Package Explorer title-bar menu
> (downward arrow icon). You may be able to specify a name filter that
> excludes *.jv~
> 2) Have you tried the Java Browsing perspective as an alternative to the
> Java perspective? I much prefer Java Browsing and IIRC it does not show
> non-.java files by default. My normal pattern of use is to spend most
> time in Java Browsing, but switch to Resource perspective when I need to
> examine non-java files. I keep other useful views as Fast Views, such as
> Ant, Synchronize, etc. for the ones that I use frequently but don't want
> to change perspective for. I also set bookmarks for non-java files that
> I open frequently so I don't have to switch to Resource perspective in
> order to find them. Bookmarks view sits nicely in a tab group with
> Console, Tasks, and Search at the bottom of my Java Browsing perspective
> (under the editors).
> HTH,
> Eric
> Eric Rizzo
> Software Architect
> Jibe, Inc.
> http://www.jibeinc.com
FUDForum. Page generated in 0.04863 seconds
