Home » Archived » BIRT » import ing java objects in Scripted datasource
import ing java objects in Scripted datasource [message #144988] Fri, 17 March 2006 05:11 Go to next message
Originally posted by: sp_res.rediffmail.com
Hi ,
I am using my java objects(ScriptedSample) in scripted datasource.I kept
the Mysample.jar(Which consist ScriptedSample.class) in
reportviewer/birt/web-inf/lib also.
i written below script in "open"
importPackage(Packages.mySample.ScriptedSample);
var sample=ScriptedSample.show();
return sample ;
Getting this exception
Caused by: org.mozilla.javascript.EcmaError: ReferenceError:
"ScriptedSample" is not defined. (DataSource[Data Source1].__bm_OPEN#4)
Can any one please tell why it is?
Thanks in Advance,
Sp
Re: import ing java objects in Scripted datasource [message #145098 is a reply to message #144988] Fri, 17 March 2006 10:19 Go to previous message
Try dropping the ScriptedSample from the importPackage
importPackage(Packages.mySample);
or just
xyz = new Packages.mySample.ScriptedSample();
xyz.show();
Jason
"sp_res" <sp_res@rediffmail.com> wrote in message
news:0ac113a2e382e474ac7f557227a119ad$1@www.eclipse.org...
> Hi ,
> return sample ;
> Thanks in Advance,
> Sp
Previous Topic:How to integrate data from 2 or more Sources in one report?
Next Topic:PB with Oracle driver
Current Time: Sat Nov 15 03:18:21 EST 2025
Powered by FUDForum. Page generated in 0.03878 seconds
