Home » Eclipse Projects » Eclipse Platform » Java Project : adding src directory
Java Project : adding src directory [message #144984] Thu, 16 October 2003 11:17 Go to next message
Originally posted by: mchacher.yahoo.fr
I'm trying to use the example of eclipse JDT documentation to change the
source path of a Java Project.
I want to create an src folder and add it to the source entry :
IClassPathEntry srcEntry = JavaCore.newSourceEntry(new
Path("/MyProject/src");
However an exception is throwed with the following message :
JavaModel Exception : Java Model Status [ Cannot nest 'MyProject/src"
inside "'MyProject'. To enable the nesting exception exclude 'src/' from
'Project'.]
Any Idea ?
Thank you for your help.
Re: Java Project : adding src directory [message #145605 is a reply to message #144984] Fri, 17 October 2003 07:04 Go to previous message
You must be getting this exception when invoking
IJavaProject.setRawClasspath(IClasspathEntry[], ...).
Ensure that you don't include a source entry whose path is '/MyProject'.
Or if you wish to keep the project source entry, add an exclusion pattern
that excludes '/MyProject/src'.
Jerome
"TransparentReady" <mchacher@yahoo.fr> wrote in message
news:bmmcpk$qqo$1@eclipse.org...
> 'Project'.]
> Any Idea ?
Previous Topic:Changing IDE background colour under Motif
Next Topic:Editor Code Annotations
Current Time: Fri Nov 07 05:28:09 EST 2025
Powered by FUDForum. Page generated in 0.02530 seconds
