Home » Archived » Test and Performance Tools Platform (TPTP) » Application can't find my *.jar
Application can't find my *.jar [message #13471] Mon, 04 April 2005 06:08 Go to next message
Originally posted by: vadimfs.web.de
I have 4 plugins in my application.
In one are only *.jar. While starting these are not found *.jar.
my serviceconfig.xml
<AgentControllerConfiguration activeConfiguration="default"
loggingDetail="LOW" loggingLevel="INFORMATION" port="10002"
securedPort="10003" version="4.0.0" filePort="10005" processPolling="true"
jvm="C:\Programme\Java\j2re1.4.2_05\bin\client\jvm.dll">
<AgentControllerEnvironment configuration="default">
<Variable name="JAVA_PATH"
value="C:\Programme\Java\j2re1.4.2_05\bin\java.exe" position="replace"/>
<Variable name="RASERVER_HOME" value="C:\tptp\raserver4.0"
<Variable name="PLUGINS_HOME" value="%RASERVER_HOME%\plugins"
<Variable name="PATH" value="%RASERVER_HOME%\bin" position="prepend"/>
<Variable name="SYS_TEMP_DIR" value="C:\WINNT\TEMP" position="replace"/>
<Variable name="LOCAL_AGENT_TEMP_DIR" value="%SYS_TEMP_DIR%"
<Variable name="CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING"
value=" %PLUGINS_HOME%\org.apache.jakarta_commons_logging_1.0.3\comm ons-logging.jar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME" position="append"
value="%PLUGINS_HOME%\org.eclipse.core.runtime_3.1.0\runtime.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_COMMON"
value=" %PLUGINS_HOME%\org.eclipse.emf.common_2.1.0\runtime\common.j ar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE"
value=" %PLUGINS_HOME%\org.eclipse.emf.ecore_2.1.0\runtime\ecore.jar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI" position="append"
value=" %PLUGINS_HOME%\org.eclipse.emf.ecore.xmi_2.1.0\runtime\ecore .xmi.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS"
position="append"
value=" %PLUGINS_HOME%\org.eclipse.tptp.platform.models_4.0.0\tptp-m odels.jar "/>
<Variable name="CLASSPATH_ORG_JUNIT" position="append"
value="%PLUGINS_HOME%\org.junit_3.8.1\junit.jar"/>
<Variable name="CLASSPATH" position="append"
value="%PLUGINS_HOME%\my.packages\lib\activation.jar"/>
value="%PLUGINS_HOME%\my.packages\lib\axis.jar"/>
value="%PLUGINS_HOME%\my.packages\lib\axis-ant.jar"/>
</AgentControllerEnvironment>
<Application configuration="default" executable="java.exe"
path="%JAVA_PATH%" location="%SYS_TEMP_DIR%"/>
<Hosts configuration="default">
<Allow host="ALL"/>
</Hosts>
<Plugin path="%PLUGINS_HOME%"/>
</AgentControllerConfiguration>
and my pluginconfig.xml
<PluginConfiguration>
value="%PLUGINS_HOME%\my.packages\activation.jar"/>
value="%PLUGINS_HOME%\my.packages\axis.jar"/>
value="%PLUGINS_HOME%\my.packages\axis-ant.jar"/>
<Option type="version" name="my.packages" value="0.1.0"/>
</PluginConfiguration>
Where CLASSPATH should be for mine plugins?
Re: Application can't find my *.jar [message #13755 is a reply to message #13471] Wed, 06 April 2005 08:48 Go to previous message
The settings in the pluginconfig.xml are picked up only if you launch your
application through the Agent Controller. Is it what you are doing? If so,
please paste the pluginconfig.xml which contains the <Application>
definition so that I can take a look. Thanks.
Samson
"Vadim" <vadimfs@web.de> wrote in message
news:09348450221a542a3db1b74de46c018f$1@www.eclipse.org...
ng.jar"
> position="append"/>
> position="append"/>
> position="append"/>
> position="append"
> <Allow host="ALL"/>
> </Hosts>
Previous Topic:JBossAgent immediately terminates after start
Next Topic:profiling filters
Current Time: Sat Jul 26 06:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.07466 seconds
