Re: [ANN] Build for Eclipse 3.4 RC2 [message #145282 is a reply to message #144927] |
Tue, 05 August 2008 07:22  |
Originally posted by: formatzeh.gmx.de
I copied your VE-version into my Eclipse-directory but it doesn't appear
in the list of plugins neither I can create a new visual class.
Anybody some ideas where to look at?
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617210 is a reply to message #144927] |
Thu, 29 May 2008 03:51  |
Originally posted by: emailmuell.posur.com
Sorry, does not work for me.
With all projects, VE stops at loading 25%
Even a new project with new visual class gives a parsing error.
"Yves YANG" <yves.yang@soyatec.com> schrieb im Newsbeitrag
news:g1kmbm$s1p$1@build.eclipse.org...
> Hi all,
> I have made a build of VE for Eclipse 3.4 RC2. Ombredanne and me are
> contacting EMO to publish it in Eclipse update system.
> You can find the build on my ftp:
> http://www.soyatec.org/update/Ganymede/org.eclipse.ve_1.4.0. v20080528.zip
> This build doesn't contain any new features. It is just a porting from the
> build for Eclipse 3.2.
> It depends on the following plugins:
> emf-sdo-xsd-SDK-2.4.0RC2.zip
> GEF-SDK-3.4.0RC1.zip
> Any feedbacks are welcome.
> Best regards
> Yves YANG
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617214 is a reply to message #144927] |
Fri, 06 June 2008 11:10  |
I have managed to get the latest VE version up and running with Eclipse
3.4 RC3, but there are a few quirks with regard to the GridBagLayout.
Firstly, if the default constructor is used to create the
GridBagConstraints object, setting any of its attributes has no effect
on the layout in the UI. The only way to ensure that the correct
constraints are used is to pass all of the desired values into the
constructor when the object is created.
The second is that the Customise Layout option no longer opens the
dialog used for editing layout attributes for a component.
Other than the above, the new version seems to be working well. Many
thanks to Yves and everyone working on the VE upgrades for Eclispe 3.4!!
Best Regards,
Matt
Yves YANG wrote:
> Hi all,
> the build for Eclipse 3.2.
> Best regards
> Yves YANG
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617229 is a reply to message #144927] |
Thu, 26 June 2008 11:48  |
Even without adding new features, making VE work with Eclipse 3.4 or at
least with 3.3 is a very good thing. Now if only official support for 3.3
would come, and not just betas, it would be a great step forward, as VE
might be one of the few major Eclipse projects that doesn't yet support
Eclipse 3.3. Then again I might be wrong, and there may be others as well.
Doesn't work for me in 3.4 [message #617232 is a reply to message #145240] |
Fri, 27 June 2008 18:18  |
It doesn't work for me in 3.4 final.
If I open any kind of RCP View or Editor or even try to create a new
Visual Class - I get an NPE.
Error Log Details:
eclipse.buildId=I20080617-2000
java.version=1.6.0_05
Framework arguments: --launcher.XXMaxPermSize256M
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri Jun 27 15:15:28 PDT 2008
Exception thrown.
org.eclipse.ve.internal.swt.ControlManager.refreshImage(Cont rolManager.java:934)
org.eclipse.ve.internal.rcp.WorkbenchPartProxyAdapter.refres hImage(WorkbenchPartProxyAdapter.java:493)
org.eclipse.ve.internal.cde.core.ImageFigureController.setIm ageNotifier(ImageFigureController.java:174)
org.eclipse.ve.internal.rcp.WorkbenchPartGraphicalEditPart.a ctivate(WorkbenchPartGraphicalEditPart.java:170)
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:152)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate (AbstractGraphicalEditPart.java:193)
org.eclipse.ve.internal.java.core.CompositionComponentsGraph icalEditPart.activate(CompositionComponentsGraphicalEditPart .java:88)
org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsGraphicalEditPart.activate(SubclassCompositionComponentsGr aphicalEditPart.java:70)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$2.run(JavaVisualEditorPart.java:2098)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Re: Doesn't work for me in 3.4 [message #617240 is a reply to message #145244] |
Tue, 08 July 2008 03:23  |
It doesn't work for me either using the same setup. It's fine until I open
something that extends ViewPart then I get a slightly different error, but
the same result, a NPE...
Using 3.4 final std RCP/plugin pkg with
EMF 2.4.0 & GEF 3.4.0 exploded into the dropins folder.
Can anyone help please?
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.NullPointerException
... 23 more
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617254 is a reply to message #144927] |
Fri, 01 August 2008 22:42  |
Originally posted by: president.runiter.org
It does get installed on my eclipse 3.4. When I use Software Updates and
Add Archieve org.eclipse.ve_1.4.0.v20080528.zip it give the following
error msg:
No repository found at
jar:file:C:\Users\Saeid\Downloads\org.eclipse.ve_1.4.0.v2008 0528.zip!/
How do I make it install? Simply unziping the zip file directly inside the
eclipse folder didn't work either.
Saeid
www.runiter.com
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617256 is a reply to message #144927] |
FUDForum. Page generated in 0.06828 seconds
