Re: Migrating 2.1.1 project to 3.0 M4 [message #146040 is a reply to message #145543] |
Fri, 17 October 2003 16:53  |
Originally posted by: mhowser.afterbot.com
Thanks for the help. I ended up my project from under the 2.1.1 workspace
directory to a non-Eclipse directory. Then, I just created a new Java
project in 3.0M4 and pointed it to the new location. It worked like a
charm.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bmobr4$f5m$1@eclipse.org...
> Matt Howser wrote:
> >So, then... I should have installed 3.0 M4 over 2.1?
> No, I would make a fresh install.
> Dani
> >"Steve Leach" <steve@kily.oldforge.local> wrote in message
> >news:pan.2003.10.16.15.49.37.343751@kily.oldforge.local...
> >>Make a backup and then open it. Eclipse will handle the upgrade.
> >>You can't use it in 2.1 afterwards though, so the backup is important.
If
> >>you use CVS, commit everything first.
> >>On Thu, 16 Oct 2003 10:43:14 -0400, Matt Howser wrote:
> >>>I just mean Java projects.
> >>>Matt
> >>>news:bmmafr$nua$1@eclipse.org...
> >>>>Matt Howser wrote:
> >>>>>What is the recommended way for migrating a 2.1.1 project to 3.0 M4?
> >>>>Do you mean porting Eclipse plug-in projects or "simply" use your Java
> >>>>projects?
> >>>>Dani
FUDForum. Page generated in 0.04117 seconds
