Home » Newcomers » Newcomers » Too Slow
Too Slow [message #144703] Thu, 23 March 2006 15:07 Go to next message
Originally posted by: router.default.gmail.com
After checking out many ide's on linux env , i found eclipse to my liking.
Problem is that it is too slow. My main(only) use is C++ .
1. It takes too long to start up
2. After that whatever i do like right click or even changing focus ,it
takes agaes to update.
3. It took me 3 hr to write a 10 line code , no kidding :-)
4. I like everthing about it ,other then first 3 points
My Platform:
CPU=Intel P4 2.4 Ghz
Memory=256 MB
Linux kernel/distro =2.6.12-10-386/kubuntu
Desktop=KDE 3.5.1
Java(java --version)=java version "1.4.2"
gij (GNU libgcj) version 4.0.2 20050808 (prerelease) (Ubuntu
4.0.1-4ubuntu9)
ECLIPSE=Platform Runtime Binary(only,which is 27 MB and not 103 MB)
eclipse-platform-3.1.2-linux-gtk.tar.gz
PLUGIN=CDT 3.02
Thats all.
Is there anyway i can increase the speed/response-time of eclipse.
I have no idea about java , am i missing some trick here ?
Or is it my requirement does not match up ?
Thanks all
Re: Too Slow [message #144730 is a reply to message #144703] Thu, 23 March 2006 16:31 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
You Java runtime of GCJ is most likely at fault. Try downloading a Sun
JRE and launch Eclipse using it, and see if that helps.
- Jeff
Re: Too Slow [message #144739 is a reply to message #144703] Thu, 23 March 2006 16:54 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
If your system is paging a lot (which I suspect it is) I would recommend
adding a bit of RAM. 256MB seems a bit low by today's standards, and
even adding only 128MB could make a huge difference.
D.
keclipse wrote:
> Problem is that it is too slow. My main(only) use is C++ . 1. It takes
> My Platform:
> Memory=256 MB
> Desktop=KDE 3.5.1
> 4.0.1-4ubuntu9)
> eclipse-platform-3.1.2-linux-gtk.tar.gz PLUGIN=CDT 3.02
> Thats all.
> Is there anyway i can increase the speed/response-time of eclipse. I
> Thanks all
Re: Too Slow: Solved [message #144801 is a reply to message #144730] Fri, 24 March 2006 05:12 Go to previous message
Thank Jeff Myers
Problem is solved , i downloaded j2sdk-1_4_2_11-linux-i586 from sun site
and now eclipse is running fast :-)
Thanks to all.
Previous Topic:How to use external DataSet for birt by application
Next Topic:two web projects use same servlets
Current Time: Sun Nov 16 10:12:48 EST 2025
Powered by FUDForum. Page generated in 0.35416 seconds
