| Running Eclipse -> no Java [message #144670] |
Mon, 23 February 2004 10:16  |
Originally posted by: iris.wegscheider.xxx.xx
I have just installed Eclipse, but there is no node 'Java' at Window ->
Preferences. The command line option -vm didn�t help, neither did copying
the jre folder into the eclipse home directory. I suppose the jre is not
found. My installed java-version is j2sdk1.4.2_03. Does anybody know this
problem and have a solution?
Thx,
Iris.
| Re: Running Eclipse -> no Java [message #144826 is a reply to message #144670] |
Mon, 23 February 2004 20:03  |
Originally posted by: dyroro.netscape.net
Iris wrote:
> Preferences. The command line option -vm didnŽt help, neither did copying
> Thx,
> Iris.
You must set the java path.
add you java path to system path
FUDForum. Page generated in 0.07367 seconds
