Home » Archived » Maven Integration (M2E) » Running test case in Eclipse?
Running test case in Eclipse? [message #13442] Wed, 23 July 2008 21:56 Go to next message
Originally posted by: barbariansouth.ymail.com
Hello all,
I've been using Maven for some time and new to the m2e plugin..... After
I installing the plugin and make my project maven enabled, I notice that
when I code some test case and want to run directly in eclipse, the
binaries of the test case seems not re-compiled and the test is executed
using the old version.... I need to manually run the "mvn install" or
something like that before my test case is refreshed during the test case
execution....
Is there any way to make my test case run with the latest binaries?
Thanks in advance...
Re: Running test case in Eclipse? [message #13462 is a reply to message #13442] Wed, 23 July 2008 22:47 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Barbarian,
Assuming you're using junit, you should be able to right-click on the
project or individual test, Run As->JUnit Test. This will construct
proper Maven test classpath (see [1] if you're interested in details)
but use Eclipse JUnit UI to show test execution progress and results.
Generally, m2e does not automatically package/installs the projects,
but, uses project output folders instead. We call it "workspace artifact
resolution". It is enabled by default for all actions performed by m2e
directly (compile classpath resolution, project import, run as junit
test, etc) but needs to be explicitly enabled for Run As Maven ...
actions (see [2]).
[1] http://docs.codehaus.org/display/M2ECLIPSE/Runtime+classpath
[2]
http://docs.codehaus.org/display/M2ECLIPSE/Developing+and+de bugging+Maven+plugins
Barbarian South wrote:
> Hello all,
> After I installing the plugin and make my project maven enabled, I
> notice that when I code some test case and want to run directly in
> eclipse, the binaries of the test case seems not re-compiled and the
> test is executed using the old version.... I need to manually run the
> "mvn install" or something like that before my test case is refreshed
> during the test case execution....
Re: Running test case in Eclipse? [message #13483 is a reply to message #13462] Thu, 24 July 2008 03:32 Go to previous messageGo to next message
I am using Junit as you assumed but without luck things seems don't
work.... Let me try from scratch.......
1. I did a mvn clean on my project manually
2. I removed all eclipse project's files (.settings / .classpath / etc...)
3. I right-click on the package-explorer and select import to import my
maven project
4. I de-selected "seperate projects for modules" (so that all sub-modules
are in the same project) and "resolve workspace project"
5. After the maven project is ready, I right-click on some test case and
run as junit test (tests are under the folder {submodule}/src/test/java)
6. The test failed with the error that it cannot found a file that were
supposed to be in {submodule}/src/main/resources.....
I tried the above steps with a single module (without submodules) and it
failed too........ any help would be appreciated....
Re: Running test case in Eclipse? [message #13504 is a reply to message #13483] Thu, 24 July 2008 03:52 Go to previous messageGo to next message
In addition, I am using Eclipse Europa 3.3.2
> maven project
Re: Running test case in Eclipse? [message #13524 is a reply to message #13504] Thu, 24 July 2008 11:00 Go to previous messageGo to next message
Can you please open bug report in JIRA [1] and provide sample project
that demonstrates the problem? [2] describes what information we
generally would like to see in a bug report.
In the mean time, you'll likely get better results with separate
projects for modules (may have to run clean build after import, to make
sure all resources are filtered/copied). Separate projects for modules
is our recommended way to work with multi-module projects as it more
closely matches behaviour of maven CLI. For example, individual modules
will have proper compile classpath, which is not possible with one
project for all modules. Likewise, individual modules can have different
eclipse natures/builders to match their pom.xml, which is not possible
for one big project.
[1] http://jira.codehaus.org/browse/MNGECLIPSE
[2] http://docs.codehaus.org/display/M2ECLIPSE/Reporting+Issues
>> etc...)
>> my maven project
>> sub-modules are in the same project) and "resolve workspace project"
>> and run as junit test (tests are under the folder
>> were supposed to be in {submodule}/src/main/resources.....
>> it failed too........ any help would be appreciated....
Re: Running test case in Eclipse? [message #13543 is a reply to message #13524] Thu, 24 July 2008 11:32 Go to previous message
I'll try to create one when I finished my task in hand. Thanks so far.
Previous Topic:stable dev build 0.9.5.20080627-1151 is published
Next Topic:How to add Eclipse marker on file when Maven build failed ?
Current Time: Mon Dec 01 05:07:08 EST 2025
Powered by FUDForum. Page generated in 0.24100 seconds
