Home » Modeling » GMF (Graphical Modeling Framework) » Problems with generating diagram code with GMF 2.0
Problems with generating diagram code with GMF 2.0 [message #144626] Sat, 28 July 2007 20:28 Go to next message
I used Eclipse 3.2.2, EMF 2.2, and GMF 1.0.3 to create EMF/GMF Editors.
The Editors are working fine.
however, I want to use the latest JET2 build, which requires Eclipse 3.3
and EMF 2.3, to generate Java code from the file produced by the editors.
so, I have to use Eclipse 3.3 to be able to use the latest JET2 with the
fixed bugs.this means, I have to use GMF 2.0 too.
I dowanloaded the latest version of Eclipse 3.3, GMF 2.0 and all its
requirements listed in its webpage.
The problem is:
when I wanted to generate Diagrame code from my *.gmfgen I got the
following error message:
Problems while generating code
Exception (Couldn't find operation 'isSuperTypeOf(EClass)' for EEnum.:in
xpt::editor::GenDiagram on line 35
'(EClass)gf.ecoreFeature.eType.isSuperTypeOf(eType)') while generating code
where the line 35 is:
<elementType
line 35 xsi:type="gmfgen:MetamodelType"
editHelperClassName="StateEditHelper"/>
I also tried to use my models created using Eclipse 3.2.2 and GMF 1.0.3 by
importing the models in Eclipse 3.3 and use "Migrate to GMF 2.0" for
gmfgraph, .gmfmap and .gmfgen but I got the same error message.
BTW: I used XML schema to produce my EMF model. also here is my *.ecore
model to give you an idea about my model:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="xmachine"
nsURI="http://www.eclipse.org/xmachine" nsPrefix="xmachine">
<eClassifiers xsi:type="ecore:EDataType" name="AllowedChar"
instanceClassName="java.lang.String">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="allowed-char"/>
<details key="baseType"
value="http://www.eclipse.org/emf/2003/XMLType#string"/>
<details key="pattern" value="([a-zA-Z0-9_])"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="AllowedString"
<eAnnotations
<details key="name" value="allowed-string"/>
<details key="pattern" value="([a-zA-Z0-9_])*"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArithmeticBinaryType">
<eAnnotations
<details key="name" value="arithmetic-binary_._type"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="arg"
lowerBound="1" eType="#//ListElement"
containment="true" resolveProxies="false">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="arg"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute"
name="arithmeticOperator" lowerBound="1"
eType="#//ArithmeticOperator" defaultValueLiteral="plus"
unsettable="true">
<eAnnotations
<details key="name" value="arithmetic-operator"/>
</eAnnotations>
name="arithmeticExpression" lowerBound="1"
eType="#//ArithmeticExpressionType" containment="true"
<eAnnotations
<details key="name" value="arithmetic-expression"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ArithmeticExpressionType">
<eAnnotations
<details key="name" value="arithmetic-expression_._type"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
name="arithmeticBinary" eType="#//ArithmeticBinaryType"
<eAnnotations
<details key="name" value="arithmetic-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ArithmeticOperator">
<eAnnotations
</eAnnotations>
<eLiterals name="plus"/>
<eLiterals name="minus" value="1"/>
<eLiterals name="multiply" value="2"/>
<eLiterals name="divide" value="3"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="ArithmeticOperatorObject"
instanceClassName="org.eclipse.emf.common.util.Enumerator">
<eAnnotations
<details key="name" value="arithmetic-operator:Object"/>
<details key="baseType" value="arithmetic-operator"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagExpressionType">
<eAnnotations
<details key="name" value="bag-expression_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bag"
eType="#//BagType"
<eAnnotations
<details key="name" value="bag"/>
</eAnnotations>
name="bagExpressionUnary" eType="#//BagExpressionUnaryType"
<eAnnotations
<details key="name" value="bag-expression-unary"/>
</eAnnotations>
name="expressionBinary" eType="#//ExpressionBinaryType"
<eAnnotations
<details key="name" value="expression-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagExpressionUnaryType">
<eAnnotations
<details key="name" value="bag-expression-unary_._type"/>
</eAnnotations>
name="bagOperatorUnary" lowerBound="1"
eType="#//BagOperatorUnary" defaultValueLiteral="cardinality"
unsettable="true">
<eAnnotations
<details key="name" value="bag-operator-unary"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bagExpression"
lowerBound="1"
eType="#//BagExpressionType" containment="true"
<eAnnotations
<details key="name" value="bag-expression"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagOfType">
<eAnnotations
<details key="name" value="bag-of_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="builtinType"
eType="#//BuiltinType"
defaultValueLiteral="integer" unsettable="true">
<eAnnotations
<details key="name" value="builtin-type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="type"
eType="#//Type" resolveProxies="false">
<eAnnotations
<details key="name" value="type"/>
</eAnnotations>
eType="#//BagType"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperator"
<eAnnotations
<details key="name" value="bag-operator"/>
<details key="memberTypes" value="bag-operator-binary
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BagOperatorBinary">
<eAnnotations
<details key="name" value="bag-operator-binary"/>
</eAnnotations>
<eLiterals name="intersection"/>
<eLiterals name="multiplicity" value="1"/>
<eLiterals name="addElement" value="2" literal="add_element"/>
<eLiterals name="deleteElement" value="3" literal="delete_element"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperatorBinaryObject"
<eAnnotations
<details key="name" value="bag-operator-binary:Object"/>
<details key="baseType" value="bag-operator-binary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BagOperatorUnary">
<eAnnotations
</eAnnotations>
<eLiterals name="cardinality"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BagOperatorUnaryObject"
<eAnnotations
<details key="name" value="bag-operator-unary:Object"/>
<details key="baseType" value="bag-operator-unary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BagType">
<eAnnotations
<details key="name" value="bag_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="bagElement"
lowerBound="1"
upperBound="-1" eType="#//ListElement" containment="true"
<eAnnotations
<details key="name" value="bag-element"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BasicTypesType">
<eAnnotations
<details key="name" value="basic-types_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
unique="false" lowerBound="1"
upperBound="-1" eType="#//AllowedString">
<eAnnotations
<details key="name" value="name"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BinaryType">
<eAnnotations
<details key="name" value="binary_._type"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="operator"
lowerBound="1"
eType="#//OperatorBinary" defaultValueLiteral="concat"
unsettable="true">
<eAnnotations
<details key="name" value="operator"/>
</eAnnotations>
name="expressionBinary" lowerBound="1"
eType="#//ExpressionBinaryType" containment="true"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BodyType">
<eAnnotations
<details key="name" value="body_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="expression"
lowerBound="1"
eType="#//ExpressionType" containment="true"
<eAnnotations
<details key="name" value="expression"/>
</eAnnotations>
name="booleanOperator" lowerBound="1"
eType="#//BooleanOperator" defaultValueLiteral="&amp;&amp;"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-operator"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="where"
lowerBound="1" eType="#//WhereType"
<eAnnotations
<details key="name" value="where"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"
instanceClassName="boolean">
<eAnnotations
<details key="name" value="boolean"/>
value="http://www.eclipse.org/emf/2003/XMLType#boolean"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionExpressionBinaryType">
<eAnnotations
<details key="name"
value="boolean-collection-expression-binary_._type"/>
</eAnnotations>
name="collectionElement" lowerBound="1"
eType="#//ListElement" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="collection-element"/>
</eAnnotations>
name="booleanCollectionOperatorBinary"
lowerBound="1" eType="#//BooleanCollectionOperatorBinary"
defaultValueLiteral="union"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-collection-operator-binary"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="collection"
lowerBound="1"
eType="#//CollectionType" containment="true"
<eAnnotations
<details key="name" value="collection"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionExpressionUnaryType">
<eAnnotations
<details key="name"
value="boolean-collection-expression-unary_._type"/>
</eAnnotations>
name="booleanCollectionOperatorUnary"
lowerBound="1" eType="#//BooleanCollectionOperatorUnary"
defaultValueLiteral="is_empty"
unsettable="true">
<eAnnotations
<details key="name" value="boolean-collection-operator-unary"/>
</eAnnotations>
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
name="BooleanCollectionOperatorBinary">
<eAnnotations
</eAnnotations>
<eLiterals name="union"/>
<eLiterals name="belongs" value="1"/>
<eLiterals name="notBelongs" value="2" literal="not_belongs"/>
</eClassifiers>
name="BooleanCollectionOperatorBinaryObject"
<eAnnotations
<details key="name"
value="boolean-collection-operator-binary:Object"/>
<details key="baseType" value="boolean-collection-operator-binary"/>
</eAnnotations>
</eClassifiers>
name="BooleanCollectionOperatorUnary">
<eAnnotations
</eAnnotations>
<eLiterals name="isEmpty" literal="is_empty"/>
<eLiterals name="notEmpty" value="1" literal="not_empty"/>
</eClassifiers>
name="BooleanCollectionOperatorUnaryObject"
<eAnnotations
<details key="name"
value="boolean-collection-operator-unary:Object"/>
<details key="baseType" value="boolean-collection-operator-unary"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BooleanComparator">
<eAnnotations
<details key="name" value="boolean-comparator"/>
</eAnnotations>
<eLiterals name="gt"/>
<eLiterals name="lt" value="1"/>
<eLiterals name="gtequal" value="2"/>
<eLiterals name="ltequal" value="3"/>
<eLiterals name="equals" value="4"/>
<eLiterals name="notEqual" value="5" literal="not_equal"/>
<eLiterals name="belongs" value="6"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanComparatorObject"
<eAnnotations
<details key="name" value="boolean-comparator:Object"/>
<details key="baseType" value="boolean-comparator"/>
</eAnnotations>
</eClassifiers>
name="BooleanExpressionComparisonType">
<eAnnotations
<details key="name" value="boolean-expression-comparison_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="identifier"
lowerBound="1"
eType="#//IdentifierType" containment="true"
<eAnnotations
<details key="name" value="identifier"/>
</eAnnotations>
name="booleanComparator" lowerBound="1"
eType="#//BooleanComparator" defaultValueLiteral="gt"
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="identifier1"
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BooleanExpressionType">
<eAnnotations
<details key="name" value="boolean-expression_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="term"
eType="#//TermType"
<eAnnotations
<details key="name" value="term"/>
</eAnnotations>
name="booleanCollectionExpressionBinary"
eType="#//BooleanCollectionExpressionBinaryType"
<eAnnotations
<details key="name" value="boolean-collection-expression-binary"/>
</eAnnotations>
name="booleanCollectionExpressionUnary"
eType="#//BooleanCollectionExpressionUnaryType" containment="true"
<eAnnotations
<details key="name" value="boolean-collection-expression-unary"/>
</eAnnotations>
name="booleanExpressionComparison"
eType="#//BooleanExpressionComparisonType" containment="true"
<eAnnotations
<details key="name" value="boolean-expression-comparison"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BooleanExpressionUnaryType">
<eAnnotations
<details key="name" value="boolean-expression-unary_._type"/>
</eAnnotations>
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanObject"
instanceClassName="java.lang.Boolean">
<eAnnotations
<details key="name" value="boolean:Object"/>
<details key="baseType" value="boolean"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BooleanOperator">
<eAnnotations
</eAnnotations>
<eLiterals name="_" literal="&amp;&amp;"/>
<eLiterals name="_1" value="1" literal="||"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BooleanOperatorObject"
<eAnnotations
<details key="name" value="boolean-operator:Object"/>
<details key="baseType" value="boolean-operator"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BuiltinType">
<eAnnotations
</eAnnotations>
<eLiterals name="integer"/>
<eLiterals name="natural0" value="1"/>
<eLiterals name="natural" value="2"/>
<eLiterals name="real" value="3"/>
<eLiterals name="char" value="4"/>
<eLiterals name="boolean" value="5"/>
<eLiterals name="true" value="6"/>
<eLiterals name="false" value="7"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BuiltinType1">
<eAnnotations
<details key="name" value="builtin_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="integer"
eType="#//Integer">
<eAnnotations
<details key="name" value="integer"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="natural0"
eType="#//Natural0">
<eAnnotations
<details key="name" value="natural0"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="natural"
eType="#//Natural">
<eAnnotations
<details key="name" value="natural"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="real"
eType="#//Real">
<eAnnotations
<details key="name" value="real"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="boolean"
eType="#//Boolean"
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="true"
eType="#//True">
<eAnnotations
<details key="name" value="true"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="false"
eType="#//False">
<eAnnotations
<details key="name" value="false"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="char"
eType="#//Char">
<eAnnotations
<details key="name" value="char"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BuiltinTypeObject"
<eAnnotations
<details key="name" value="builtin-type:Object"/>
<details key="baseType" value="builtin-type"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="Char"
<eAnnotations
<details key="length" value="1"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CollectionType">
<eAnnotations
<details key="name" value="collection_._type"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="sequence"
eType="#//SequenceType"
<eAnnotations
<details key="name" value="sequence"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="set"
eType="#//Set" containment="true"
<eAnnotations
<details key="name" value="set"/>
</eAnnotations>
eType="#//BagType"
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="variable"
<eAnnotations
<details key="name" value="variable"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="basicTypes"
eType="#//BasicTypesType"
<eAnnotations
<details key="name" value="basic-types"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CompoundExpressionType">
<eAnnotations
<details key="name" value="compound-expression_._type"/>
</eAnnotations>
name="booleanExpression" lowerBound="1"
eType="#//BooleanExpressionType" containment="true"
<eAnnotations
<details key="name" value="boolean-expression"/>
</eAnnotations>
unsettable="true">
<eAnnotations
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="condition"
lowerBound="1"
eType="#//ConditionType" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="condition"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ConditionType">
<eAnnotations
sou
Re: Problems with generating diagram code with GMF 2.0 [message #144677 is a reply to message #144626] Mon, 30 July 2007 04:16 Go to previous messageGo to next message
Hello Tarek,
> EEnum.:in
> code
Looks like an error in xpand templates. Can you please submitt bugzilla entry
for it?
Alex Shatalin
Re: Problems with generating diagram code with GMF 2.0 [message #144692 is a reply to message #144677] Mon, 30 July 2007 05:10 Go to previous messageGo to next message
Dear Alex Shatalin:
Thanks for your reply.
I have submitted a Bugzilla entry. the Bug#: 198238.
My question is:
how long it will take to fix this bug?(I am doing my university
dissertation, and I do not have time).
Is there a vesrion of Eclipse 3.3 that does not have this bug and also
works with the latest JET2 build, so I can use it.
Thank you in advance
Tarek
Re: Problems with generating diagram code with GMF 2.0 [message #144729 is a reply to message #144692] Mon, 30 July 2007 08:16 Go to previous messageGo to next message
Hi Tarek,
As a quick workaround, I may suggest to add to the GenDiagram.ext file
the following declaration:
private boolean isSuperTypeOf(ecore::EClassifier one, ecore::EClassifier
another) :
false
This is not a permanent fix, but could at least let you proceed without
waiting for us to fix this bug.
Sorry for the inconvenience and
Boris
Tarek wrote:
> Dear Alex Shatalin:
> My question is:
> Tarek
Re: Problems with generating diagram code with GMF 2.0 [message #144803 is a reply to message #144729] Mon, 30 July 2007 13:20 Go to previous message
Dear Boris:
Thank you very nuch for your help, I really appreciate that.
Best regards
Tarek
Previous Topic:Access EditPart's model within a LayoutManager
Next Topic:EdgeEditParts and NodeEditParts
Current Time: Tue Nov 18 08:55:18 EST 2025
Powered by FUDForum. Page generated in 0.04212 seconds
