Home » Archived » BIRT » thin JDBC to large DB
thin JDBC to large DB [message #144620] Thu, 16 March 2006 12:46 Go to next message
We are using a thin JDBC connection to setup BIRT datasources & datasets to
an Oracle datawarehouse that has a large # of users (14K+), and lots of
tables (4.7K+)...(and lots of table-cols, of course...41K+)
The problem is that the DataSet Editor either:
1. takes forever, and/or
5. uses all available memory
....apparently querying/loading every schema and/or table/view and/or column
in the instance.
Does anyone have a suggestion of how we might be able to handle this better?
P.S. We have no problems connecting to smaller instances.
Re: thin JDBC to large DB [message #145721 is a reply to message #144620] Fri, 17 March 2006 16:43 Go to previous messageGo to next message
I suggest that you file a Bugzilla bug for this issue.
thanks,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"BITBURNER" <rileymg@indiana.edu> wrote in message
news:dvc8eo$p6$1@utils.eclipse.org...
to
column
> in the instance.
better?
Re: thin JDBC to large DB [message #145793 is a reply to message #144620] Sat, 18 March 2006 18:50 Go to previous messageGo to next message
We have exactly the same problem with a much smaller db. If you find a
solution let me know.
Birt.
> to an Oracle datawarehouse that has a large # of users (14K+), and lots of
> column in the instance.
> better?
Re: thin JDBC to large DB [message #149303 is a reply to message #145793] Wed, 29 March 2006 12:14 Go to previous messageGo to next message
So far, we are having to use the sun jdbc/odbc bridge ...which we are not
happy about because Oracle/odbc will be a real pain to have to rollout to
our users (...and to support it!).
"birt" <birt@ohds.co.uk> wrote in message
news:dvi6ba$eqk$1@utils.eclipse.org...
> Birt.
>> of tables (4.7K+)...(and lots of table-cols, of course...41K+)
>> better?
Re: thin JDBC to large DB [message #149328 is a reply to message #149303] Wed, 29 March 2006 17:42 Go to previous messageGo to next message
Please let me know when you have the Bugzilla entry in, I would like to
track on this one.
Scott Rosenbaum
BIRT PMC
>> Birt.
>>> better?
Re: thin JDBC to large DB [message #192492 is a reply to message #149328] Mon, 25 September 2006 17:36 Go to previous message
This bottleneck occurs when you have a lot of users defined to your Oracle
DB. We were able to get around the problem by creating a view (under ea. of
our own schemas) of sys.all_users that selects only a small sub-set of
Oracle users:
CREATE VIEW ALL_USERS AS
select *
from sys.all_users where username in ('SOURCE1','SOURCE2' ,'SOURCE2')
....A bit clumsy, but it works for us until BIRT optimizes the way the use
this Oracle table in the query tool.
"Scott Rosenbaum" <scottr@innoventsolutions.com> wrote in message
news:e0f2g7$is0$1@utils.eclipse.org...
> track on this one.
> Scott Rosenbaum
> BIRT PMC
>>> Birt.
>>>> datasets to an Oracle datawarehouse that has a large # of users (14K+),
>>>> and lots of tables (4.7K+)...(and lots of table-cols, of course...41K+)
>>>> better?
Previous Topic:Is this possible with the birt charting engine?
Next Topic:Expression Question
Current Time: Sun Nov 30 12:24:11 EST 2025
Powered by FUDForum. Page generated in 0.25637 seconds
