Home » Newcomers » Newcomers » Cobol
Cobol [message #144605] Thu, 23 March 2006 05:53 Go to next message
Originally posted by: henry.philippe.free.fr
lors de l'utilisation du plug in iDE cobol et en créationde projet
j'obtient l'erreur suivante :
Erreur 2006-03-23 11:47:23.781
org.eclipse.ui.internal.ide.IDEWorkbenchMessages.getString(L java/lang/String;)Ljava/lang/String;
java.lang.NoSuchMethodError:
org.eclipse.cobol.ui.wizards.projectmanagement.CustomWizardN ewProjectCreationPage.createProjectNameGroup(CustomWizardNew ProjectCreationPage.java:230)
org.eclipse.cobol.ui.wizards.projectmanagement.CustomWizardN ewProjectCreationPage.createControl(CustomWizardNewProjectCr eationPage.java:148)
org.eclipse.cobol.ui.wizards.projectmanagement.NewProjectCre ationPage.createControl(NewProjectCreationPage.java:50)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1020)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
que faire ? merci
Re: Cobol [message #145258 is a reply to message #144605] Sat, 25 March 2006 21:02 Go to previous message
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> que faire ? merci
c'est un newsgroup speeking anglais. Vous parierez des personnes pour
répondre si en utilisant l'anglais. Le meilleur que je peux faire est
poisson de Babel.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Previous Topic:Problems with tomcat
Next Topic:2 Questions
Current Time: Sat Jun 21 10:40:35 EDT 2025
Powered by FUDForum. Page generated in 0.09879 seconds
