Home » Language IDEs » C / C++ IDE (CDT) » cross compiler
cross compiler [message #144212] Fri, 29 April 2005 08:36 Go to next message
Originally posted by: wenliangzh.yahoo.com
I am using eclipse in Linux x86.My embeded system is MIPS.How can I do the
cross compile from x86 to MIPS.How can I do the remote debug?Is there
emulator for MIPS on Linux x86?
mao
Re: cross compiler [message #144291 is a reply to message #144212] Sat, 30 April 2005 02:27 Go to previous messageGo to next message
Hello Mao,
El vie, 29-04-2005 a las 12:36 +0000, mao escribió:
None of this questions are particularly relevant to CDT. You'll have
better look heading to GCC's homepage first, or look for some
MIPS-specific GCC documentation on the net. Once you get all that
working, getting Eclipse to use it should be much easier.
Javier Kohen <jkohen@users.sourceforge.net>
ICQ: blashyrkh #2361802
Jabber: jkohen@jabber.org
Re: cross compiler [message #144316 is a reply to message #144212] Sat, 30 April 2005 12:30 Go to previous messageGo to next message
You could write CDT extensions for the the compiler & debugger.
There is information about it in the faq page of CDT
"mao" <wenliangzh@yahoo.com> ha escrit en el missatge dels grups de
discussi
Re: cross compiler [message #144395 is a reply to message #144212] Mon, 02 May 2005 04:32 Go to previous message
Originally posted by: johan.nosp.m.appeal.se
Regarding the cross compilation, Google is your friend. Try searching
for "gcc cross compilation". Get that working from the command line
first, before you try to do it from within the CDT.
As for the remote debugging, the CDT support for this is currently
limited, but voting for / CCing yourself to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30094 should give you a
notification when this Great Leap Forward happens.
Regards //Johan
mao wrote:
> the cross compile from x86 to MIPS.How can I do the remote debug?Is
> there emulator for MIPS on Linux x86?
> Thanks
> mao
Previous Topic:Help me,or I'll be fired!
Next Topic:c++ question
Current Time: Sat Nov 08 23:45:27 EST 2025
Powered by FUDForum. Page generated in 0.03624 seconds
