Home » Language IDEs » Java Development Tools (JDT) » more documentation on refactoring source code?
more documentation on refactoring source code? [message #144187] Fri, 20 February 2004 23:32 Go to next message
Originally posted by: lshan.imail.eecs.berkeley.edu
Hi all,
Where can i find more documenation on the refactoring source code?
for example, i want more infomation about:
org.eclipse.jdt.internal.corext.refactoring.base
org.eclipse.jdt.internal.corext.refactoring.code
Those source files have no documentation at all. The developers must be
keeping a great deal of documenations somewhere else. Can any body point me
a way?
Thank you very much
Lexin
Re: more documentation on refactoring source code? [message #144196 is a reply to message #144187] Fri, 20 February 2004 23:39 Go to previous message
me
> a way?
nope, there's nothing else - all doc is in the source.
the extensive refactoring test suite is the spec of how this code should
work.
Lexin, do you have a specific question about the design or implementation of
that code?
btw, some parts of refactoring will be API in 3.0 - that will be documented
in detail.
a.
Previous Topic:3.0m7 build 200310101454 - read file in: "c:\Program Files" fails when using getResource
Next Topic:Dam! Eclipse is Nice !
Current Time: Mon Sep 22 15:31:30 EDT 2025
Powered by FUDForum. Page generated in 0.05751 seconds
