Home » Eclipse Projects » GEF » [Draw2D] Circle/Oval Layout?
[Draw2D] Circle/Oval Layout? [message #144120] Thu, 22 July 2004 23:56 Go to next message
Originally posted by: ckng.nrg.cs.usm.my
Anyone know if there is any layout that can place Figures in a circular/oval
fashion like depicted below, where o are the Figures (number denotes the
layout sequence). Or have idea which existing layout can be
duplicated/modified to get such functionality..
o1
4o--o--o2
o3
o o5
o--o--o
7o o o6
I'm thinking maybe can reuse some code from FanRouter, but I couldnt get it
to work properly.
CK Ng
Re: [Draw2D] Circle/Oval Layout? [message #144176 is a reply to message #144120] Fri, 23 July 2004 09:58 Go to previous messageGo to next message
Routers only affect connections, not nodes. You need a layout which places
nodes based on their connections. This could be done by writing your own
layout manager which takes constraints or something similar. You could set
constraints on each node indicating which other nodes it is attached to.
Or, you could just invent some new API for your layout which allows you to
push all of the information into it.
Once you place the nodes, connection could be router simply using chopbox
anchors or similar.
"CK Ng" <ckng@nrg.cs.usm.my> wrote in message
news:cdq22d$esc$1@eclipse.org...
circular/oval
> o1
> 4o--o--o2
> o3
> o o5
> o--o--o
> 7o o o6
it
> to work properly.
> Thanks
> CK Ng
Re: [Draw2D] Circle/Oval Layout? [message #144248 is a reply to message #144176] Fri, 23 July 2004 23:05 Go to previous message
I think I know where to go from here.
I need to write a new Layout that calculate the position/constraints of each
Figure on the circle based on number of nodes (360 deg/number of nodes) and
use some ConnectionRouter to connect them..
CK Ng
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cdr5eh$37l$1@eclipse.org...
anchors or similar.
circular/oval
> o1
> 4o--o--o2
> o3
> o o5
> o--o--o
> 7o o o6
it
> to work properly.
> Thanks
> CK Ng
Previous Topic:Building a tree using GEF?
Next Topic:How to run the GEF redbook example
Current Time: Sat Nov 08 01:04:26 EST 2025
Powered by FUDForum. Page generated in 0.03633 seconds
