Home » Eclipse Projects » JFace » [Databinding] binding to objects attributes
[Databinding] binding to objects attributes [message #13379] Wed, 10 June 2009 08:32 Go to next message
is it possible to bind to attributes of objects within objects?
E.g. I have an Object Person with the attributes:
String firstName;
String lastName;
Address address;
where Address is an object with the attribute:
String street;
Can I bind direct to street via the person object? Something like this:
BeansObservables.observeValue(person, "address.street");
Or do I to use
BeansObservables.observeValue(person.getAddress(), "street");
Best regards, Lars
Re: [Databinding] binding to objects attributes [message #13400 is a reply to message #13379] Wed, 10 June 2009 08:45 Go to previous messageGo to next message
With 3.4 you need to do this your own
-----------8<-----------
IObservable parent = BeansObservables.observeValue(person,"address");
IObservableValue child =
BeansObservables.observeDetail(parent,"street",Person.class);
With 3.5 this works out of the box (when using Properties-API):
IObservableValue v = BeanProperties.value("address.street").observe(person);
You can read some details in my current blog. I'm discussing this at
EMF-Level but the code is the same for Beans. The nice thing with 3.5 is
that this even works in Table/Trees :-)
Tom
[1] http://tomsondev.bestsolution.at/2009/06/07/galileo-emf-data binding-part-2/
Lars Vogel schrieb:
> String firstName;
> String lastName;
> Address address;
> String street;
> Or do I to use
> Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14063 is a reply to message #13400] Wed, 10 June 2009 10:33 Go to previous messageGo to next message
Hi Tom,
xool, this is a nice feature in Eclipse 3.5.
I'll add a beans example to my databinding tutorial and put your blog
entries as references into it:
http://www.vogella.de/articles/EclipseDataBinding/article.ht ml
Thank you,
Lars
Tom Schindl wrote:
> Tom
> Lars Vogel schrieb:
>> String firstName;
>> String lastName;
>> Address address;
>> String street;
>> Or do I to use
>> Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14130 is a reply to message #13400] Wed, 10 June 2009 15:30 Go to previous messageGo to next message
Hi Tom,
thanks again, I included a tiny bean example for the Properties API in
my tutorial.
Best regards, Lars
Tom Schindl wrote:
> Tom
> Lars Vogel schrieb:
>> String firstName;
>> String lastName;
>> Address address;
>> String street;
>> Or do I to use
>> Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14147 is a reply to message #14130] Wed, 10 June 2009 17:56 Go to previous message
I just saw that there's a bug in my example :-) Naturally the second
line should be:
BeansObservables.observeDetail(parent,"street",Address.class);
Tom
Lars Vogel schrieb:
> Hi Tom,
> my tutorial.
> Best regards, Lars
> Tom Schindl wrote:
>> Tom
>> Lars Vogel schrieb:
>>> Hi,
>>> String firstName;
>>> String lastName;
>>> Address address;
>>> String street;
>>> Or do I to use
>>> Best regards, Lars
Previous Topic:[DataBinding] WizardScreen not fully updated
Next Topic:Issue with EditingSupport#canEdit
Current Time: Mon Dec 01 05:08:34 EST 2025
Powered by FUDForum. Page generated in 0.03806 seconds
