Re: Search/browse Java documentation in Eclipse? [message #144414 is a reply to message #144061] |
Wed, 22 March 2006 07:30  |
Originally posted by: johann.petrak.gmail.com
Thank you for the answer. I still do not understand this though: how cam I
then search and view the Javadoc in Eclipse? Do I need a seperate plugin?
Also, what I wanted to do is to simply make the seperate Javadoc zipfile I
downloaded from Sun (jdk-1_5_0-doc.zip which contains all the html files)
available and usable from within Eclipse. The idea is that I can than
bring up the documentation of any element in the buffer (e.g. Character)
within Eclipse and maybe also use it for code completion.
What am I missing here?
Marcin Dobosz wrote:
> Yes,
> you need to go to Window->Preferences->Java->Installed JREs and add your
> installed copy of a JDK to the list and set it to be the default JRE.
> By default, eclipse detects a copy of the JRE, which does not have the
> source code attached to it.
> "jope" <johann.petrak@gmail.com> wrote in message
> news:1790b3af4ab2edcbd0329b8b0e386a48$1@www.eclipse.org...
>> Is there a way to search/browse the Sun Java documentation from within
>> Eclipse similar as in Netbeans?
FUDForum. Page generated in 0.09514 seconds
