Home » Eclipse Projects » DSDP - Target Management » ssh authentication help
ssh authentication help [message #13372] Thu, 02 August 2007 03:28 Go to next message
Hi All,
I am trying to connect remote system using RSE Framework. If the remote
system is an unknown_user, my application is failing to activate the ssh
authentication menu with
"The authenticity of host '123.45.6.786' can't be established. RSA key
fingerprint is d7:d1:8f:9c:3b:14:d8:ba:c7:42:fc:06:5f:fd:75:62. Are you
sure you want to continue connecting?"
message. could you please help me.
Thanks in advance
HariBabu
Re: ssh authentication help [message #13392 is a reply to message #13372] Thu, 02 August 2007 12:52 Go to previous messageGo to next message
Hello Hari Babu,
this may be a hard problem to fix.
Currently, TM/RSE do still not quite well separate UI and non-UI parts,
they are not fully prepared for operation without a user sitting in
front. Working on these limitations and make a really good UI / Non-UI
split is one of the top priorities for our next release (TM 3.0 next year).
I assume that your launchShell() command hangs because it's waiting
for the user to accept the dialog ("Authenticity of host..."). That
dialog is displayed by the org.eclipse.ui.jsch plugin and we do not have
a lot of influence on it.
Can you give a little bit more information about your program, and
what you are trying to accomplish. Perhaps you could programmatically
add the host key and / or answer the dialog.
At any rate, please file a bugzilla bug for further discussing this.
It is an important use case we should not forget when working
towards next year's release.
Martin Oberhuber
Wind River Systems, Inc.
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
HariBabu wrote:
> Hi All,
> Thanks in advance
> HariBabu
Re: ssh authentication help [message #14024 is a reply to message #13392] Fri, 03 August 2007 07:27 Go to previous message
This is now being discussed on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198790
Martin Oberhuber
Martin Oberhuber wrote:
> Hello Hari Babu,
> Martin Oberhuber
> HariBabu wrote:
>> Hi All,
>> remote system is an unknown_user, my application is failing to
>> activate the ssh authentication menu with
>> you sure you want to continue connecting?"
>> Thanks in advance
>> HariBabu
Re: ssh authentication help [message #569557 is a reply to message #13372] Thu, 02 August 2007 12:52 Go to previous message
Hello Hari Babu,
Martin Oberhuber
HariBabu wrote:
> Hi All,
> Thanks in advance
> HariBabu
Re: ssh authentication help [message #569581 is a reply to message #13392] Fri, 03 August 2007 07:27 Go to previous message
Martin Oberhuber
> Hello Hari Babu,
> Martin Oberhuber
> HariBabu wrote:
>> Hi All,
>> Thanks in advance
>> HariBabu
Previous Topic:ssh authentication help
Next Topic:SystemStartHere.getSystemRegistry() returns null
Current Time: Mon Dec 01 05:07:43 EST 2025
Powered by FUDForum. Page generated in 0.09467 seconds
