Home » Eclipse Projects » GEF » CompoundDirectedGraphLayout and left-to-right ordering
CompoundDirectedGraphLayout and left-to-right ordering [message #143807] Wed, 21 July 2004 14:18 Go to next message
Originally posted by: q2tn65p02.sneakemail.com
In "Re: CompoundDirectedGraphLayout - with constrained nodes", Randy
Hudson wrote:
> I have unreleased code which adds support for a constraint index.
Nodes and
> Subgraphs may have a value indicating the relative left-to-right
> order in which they should appear. It is not well tested and is not
> being released for 3.0.
> Is this relative ordering what you are looking for? Or do you want
absolute
> positioning of a node?
Randy,
I am interested in the above. Can I get it in the latest integration
builds or do I need to get it from the cvs? Is there example code using
the left-to-right ordering? When is this code planned to be released
(approximately)?
Thanks!
Vineet
Re: CompoundDirectedGraphLayout and left-to-right ordering [message #144307 is a reply to message #143807] Sat, 24 July 2004 18:25 Go to previous messageGo to next message
I would appreciate any pointers about the question below (about left to
right ordering with compount directed graph layout)...
Thanks!
Vineet
>> Nodes and Subgraphs may have a value indicating the relative
>> left-to-right order in which they should appear. It is not well
>> tested and is not being released for 3.0.
>> absolute positioning of a node?
> Randy,
> (approximately)?
> Thanks!
> Vineet
Re: CompoundDirectedGraphLayout and left-to-right ordering [message #144415 is a reply to message #144307] Mon, 26 July 2004 09:26 Go to previous messageGo to next message
I will release this to the HEAD stream (3.1 builds) as soon as I have a few
JUnits in place.
"Vineet Sinha" <q2tn65p02@sneakemail.com> wrote in message
news:cdunha$5m6$1@eclipse.org...
> Thanks!
Re: CompoundDirectedGraphLayout and left-to-right ordering [message #145579 is a reply to message #144415] Thu, 29 July 2004 19:39 Go to previous message
A pointer on an example that uses (or code that deals with) such
ordering will be helpful. Also, a reference to any papers that you used
to figure out the implementation (in case I need to go into its guts
looking for bugs / improving it) will be helpful..
I am guessing this means that it will then be available in the next
integration build (after you release it to the HEAD stream). I would
appreciate it if you could post a note as to when this happens.
Thanks!
Vineet
> JUnits in place.
>>Thanks!
Previous Topic:Changing figures for edit parts
Next Topic:add figure behind its parent
Current Time: Tue Jul 22 22:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.29632 seconds
