ClassCasteException when working with tutoial [message #143761] |
Wed, 21 July 2004 10:37  |
I am trying to use the GEF tutorial to learn how to use GEF. I have a
root editpart and an editpart for the nodes in my diagram. I am trying
to build a tree like structure using editparts and connectors. I return
a list from getModelTargetConnects, and the editpart on both ends of the
connection implement NodeEditPart, but I get a ClassCasteException when
running the sample. I'm pretty sure it's related to this because it was
working before i returned the Connections. Here is the stack trace:
!SESSION Jul 20, 2004 17:14:26.811
eclipse.buildId=unknown
java.version=1.4.2_03
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Command-line arguments: -application org.eclipse.ui.ide.workbench
!ENTRY org.eclipse.core.runtime 4 2 Jul 20, 2004 17:14:26.813
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ClassCastException
org.eclipse.gef.editparts.AbstractGraphicalEditPart.createCo nnection(AbstractGraphicalEditPart.java:262)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.createOr FindConnection(AbstractGraphicalEditPart.java:289)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshT argetConnections(AbstractGraphicalEditPart.java:640)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:540)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:219)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:196)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:182)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:736)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:686)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:538)
org.eclipse.gef.editparts.ScalableRootEditPart.setContents(S calableRootEditPart.java:365)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:557)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:566)
at geftest.GefEditor.initializeGraphicalViewer(GefEditor.java:4 7)
org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEditor.java:117)
org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:127)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:110 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:697)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:686)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:782)
at org.eclipse.ui.internal.EditorManager.access$12(EditorManage r.java:766)
at org.eclipse.ui.internal.EditorManager$9.run(EditorManager.ja va:951)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:925)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:918)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:914)
org.eclipse.ui.internal.EditorManager.restoreEditorState(Edi torManager.java:1559)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:877)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2427)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1372)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:167)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Thanks for the help
Re: ClassCasteException when working with tutoial [message #143769 is a reply to message #143761] |
Wed, 21 July 2004 12:08   |
Your getModel*Connections() returns connections, right? And your factory
creates ConnectionEditParts for them?
"Marc Boorshtein" <marc.boorshtein@octetstring.com> wrote in message
news:cdlv19$ntg$1@eclipse.org...
> Hello,
> !STACK 0
> at
> at
> at
> at
lEditPart.java:540)
> at
19)
> at
> at
2)
> at
java:736)
> at
> at
lEditPart.java:538)
> at
19)
> at
> at
2)
> at
art.java:365)
> at
Viewer.java:557)
> at
Viewer.java:566)
> at
or.java:117)
> at
ava:127)
> at
:615)
> at
a:939)
> at
va:59)
> at
266)
> at
> at
782)
> at
:615)
> at
25)
> at
> at
1559)
> at
> at
> at
72)
> at
:615)
> at
..java:167)
> at
a:652)
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> Thanks for the help
Re: ClassCasteException when working with tutoial [message #143812 is a reply to message #143769] |
Wed, 21 July 2004 14:37   |
so the list should contain connections? i thought it contained the
models that represent the endpoints? Or will the objects that i return
get sent to my factory and the factory needs to generate connections?
>>Hello,
>>!STACK 0
>>at
>>at
>>at
>>at
> lEditPart.java:540)
>>at
> 19)
>>at
>>at
> 2)
>>at
> java:736)
>>at
>>at
> lEditPart.java:538)
>>at
> 19)
>>at
>>at
> 2)
>>at
> art.java:365)
>>at
> Viewer.java:557)
>>at
> Viewer.java:566)
>>at
> or.java:117)
>>at
> ava:127)
>>at
> :615)
>>at
> a:939)
>>at
> va:59)
>>at
> 266)
>>at
>>at
> 782)
>>at
> :615)
>>at
> 25)
>>at
>>at
> 1559)
>>at
>>at
>>at
> 72)
>>at
> :615)
>>at
> .java:167)
>>at
> a:652)
>>at
>>at
> java:335)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
> .java:25)
>>Thanks for the help
Re: ClassCasteException when working with tutoial [message #143817 is a reply to message #143812] |
Wed, 21 July 2004 15:51   |
The list should contain whatever you have in your model that represents
connections (not the nodes themselves). In the logic example, this is the
Wire. These model objects will then be sent to the factory, which should
create ConnectionEditParts for them (GraphicalPartFactory creates
WireEditParts for Wires).
news:cdmd2c$jfe$1@eclipse.org...
factory
> >>Hello,
> >>!STACK 0
> >>at
> >>at
> >>at
> >>at
> > lEditPart.java:540)
> >>at
> > 19)
> >>at
> >>at
> > 2)
> >>at
> > java:736)
> >>at
> >>at
> > lEditPart.java:538)
> >>at
> > 19)
> >>at
> >>at
> > 2)
> >>at
> > art.java:365)
> >>at
> > Viewer.java:557)
> >>at
> > Viewer.java:566)
> >>at
> > or.java:117)
> >>at
> > ava:127)
> >>at
> > :615)
> >>at
> >>at
> > a:939)
> >>at
> > va:59)
> >>at
> > 266)
> >>at
> >>at
> > 782)
> >>at
> >>at
> > :615)
> >>at
> > 25)
> >>at
> >>at
> > 1559)
> >>at
> >>at
> >>at
> > 72)
> >>at
> > :615)
> >>at
> > .java:167)
> >>at
> > a:652)
> >>at
> >>at
> >>at
> > java:335)
> >>at
> >>at
> >>at
> >>at
> > .java:25)
> >>Thanks for the help
Re: ClassCasteException when working with tutoial [message #143855 is a reply to message #143817] |
Wed, 21 July 2004 18:29  |
AHHHHHHH. That makes sence. Thanks for the explination!
> factory
>>>>Hello,
>>>>!STACK 0
>>>>at
>>>>at
>>>>at
>>>>at
>>>lEditPart.java:540)
>>>>at
>>>19)
>>>>at
>>>>at
>>>2)
>>>>at
>>>java:736)
>>>>at
>>>>at
>>>lEditPart.java:538)
>>>>at
>>>19)
>>>>at
>>>>at
>>>2)
>>>>at
>>>art.java:365)
>>>>at
>>>Viewer.java:557)
>>>>at
>>>Viewer.java:566)
>>>>at
>>>or.java:117)
>>>>at
>>>ava:127)
>>>>at
>>>:615)
>>>>at
>>>>at
>>>a:939)
>>>>at
>>>va:59)
>>>>at
>>>266)
>>>>at
>>>>at
>>>782)
>>>>at
>>>>at
>>>:615)
>>>>at
>>>25)
>>>>at
>>>>at
>>>1559)
>>>>at
>>>>at
>>>>at
>>>72)
>>>>at
>>>:615)
>>>>at
>>>.java:167)
>>>>at
>>>a:652)
>>>>at
>>>>at
>>>>at
>>>java:335)
>>>>at
>>>>at
>>>>at
>>>>at
>>>.java:25)
>>>>Thanks for the help
FUDForum. Page generated in 0.55099 seconds
