Home » Language IDEs » C / C++ IDE (CDT) » Debugging lpc2138 arm7 through Eclipse
Debugging lpc2138 arm7 through Eclipse [message #143587] Tue, 19 April 2005 16:04 Go to next message
Originally posted by: bluesboys.-remove.me-hotmail.com
Hi everybody
I'm trying to debug a program running on a lpc2138 microprocessor through
the Eclipse CDT 2.1.1 and a OCDRemote/Raven OCDemon combo. Since the lpc2138
is a ARM7 processor, I'm using the GNU ARM toolchain which includes the
arm-elf-gdb debugger.
When running from a console, the gdb works alright, allowing me to load the
program to the the processor, step through the programs source code and
inserting breakpoints. But when running from Eclipse none of this is
possible. It just starts running resulting in the processor to get stuck in
the bootloader (I need to tell GDB that the program starts at address
0x40000000)
Is it possible to tell gdb from CDT which address to start the execution?
I've also tried debugging from the uVision IDE (from Keil) and this program
uses an .ini file to initialise the program counter to 0x40000000 where the
programs startup code is situated. Is it possible to use such a file in CDT?
Finally I would like to know if anyone has any experience in debugging a
ARM7 processor through JTAG from Eclipse?
Best Regards
S
Re: Debugging lpc2138 arm7 through Eclipse [message #143732 is a reply to message #143587] Wed, 20 April 2005 07:49 Go to previous message
Originally posted by: bluesboys.-remove-this-hotmail.com
"Hansen" <bluesboys@-remove.me-hotmail.com> wrote in message
news:d43o9c$2o1$1@news.eclipse.org...
> Hi everybody
> lpc2138 is a ARM7 processor, I'm using the GNU ARM toolchain which
> includes the arm-elf-gdb debugger.
> the program to the the processor, step through the programs source code
> and inserting breakpoints. But when running from Eclipse none of this is
> in the bootloader (I need to tell GDB that the program starts at address
> 0x40000000)
> program uses an .ini file to initialise the program counter to 0x40000000
> where the programs startup code is situated. Is it possible to use such a
> file in CDT?
> Best Regards
> S
Previous Topic:CDTProject already exists?
Next Topic:Current File in Editor for Makefile
Current Time: Sat Jul 26 10:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.05183 seconds
