Home » Eclipse Projects » GEF » How to use GEF with RCP
How to use GEF with RCP [message #143535] Tue, 20 July 2004 05:59 Go to next message
Originally posted by: yogender.globalworldtech.com
Hello
I want to use HelloGef example from http://eclipse-wiki.info/GefExamples
with RCP application in eclipse3.0.
I am able to run it as Workbench application but now I want to use this
with RCP application.
Plese Help me
Yogender
Re: How to use GEF with RCP [message #143789 is a reply to message #143535] Wed, 21 July 2004 12:24 Go to previous messageGo to next message
Originally posted by: turker.keskinpala.vanderbilt.edu
I suppose you mean you want to modify an example. You should be able to
download the specific example code or plugin and import it on your
workbench. If you are importing an existing plugin make sure "Project with
source folder" option is selected in "Import As" section of the import
wizard.
HTH,
Turker
"Yogender" <yogender@globalworldtech.com> wrote in message
news:cdiqe4$fo9$1@eclipse.org...
> Hello
> Plese Help me
> Thanks
> Yogender
Re: How to use GEF with RCP [message #144128 is a reply to message #143789] Fri, 23 July 2004 00:39 Go to previous messageGo to next message
i have dowloaded the specific example and necessary plugin. And its
working fine when i run my application as run time workbench.
But I have one RCP appliaction and HelloGef1 example. So when I run this
RCP application the editor part with diagram should appear.
How to do this please help me.
Yogender
> wizard.
> HTH,
> Turker
> > Hello
> > Plese Help me
> > Thanks
> > Yogender
How to use GEF with RCP [message #144137 is a reply to message #143789] Fri, 23 July 2004 00:48 Go to previous message
Yogender
> wizard.
> HTH,
> Turker
> > Hello
> > Plese Help me
> > Thanks
> > Yogender
Previous Topic:GEF Shape Properties Window
Next Topic:ZoomManager does not contain FIT_ALL
Current Time: Tue Oct 28 03:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.03964 seconds
