| Re: [ANN] release 1.0.9 of metrics plugin is now ready [message #13287 is a reply to message #13260] |
Sun, 04 May 2003 23:11  |
A little note on usage of the dependency graph (didn't get a chance to
update docs yet):
a package fragment root (source folder) has to be selected and the metrics
have to be
fully calculated. The view's drop down has a menu item for the dependency
graph that
is now enabled. Red nodes and edges are part of cyclic dependencies, blue
ones are not.
The reason the graph only works for source folders is that it displays
package dependencies,
and a source folder selection is the only way to ensure they have all been
calculated.
On windows the graph is displayed in a workbench view, on all other
platforms as a separate (AWT) window, as it is using the touchgraph library,
and a
first attempt to port it to SWT was not very successful.
For more on this library, see : http://www.touchgraph.com
"Frank Sauer" <sauerf@yahoo.com> wrote in message
news:b94k5s$hti$1@rogue.oti.com...
> * added Robert Martin coupling metrics
> * added dependency graph view using TouchGraph (AWT for now)
> * refactored
> * extensible exporter architecture
> * safe ranges on metrics and warnings for out of range values
> * column-widths bug fixed and view now persists the user selected widths
> across sessions
> Go to http://www.sourceforge.net/projects/metrics for download
> Frank
FUDForum. Page generated in 0.07047 seconds
